Thomson 29DX25KG шасси ICC17 | |
Yuritsh 14/11/2009 01:06 |
Thomson 29DX25KG шасси ICC17 / Thomson 21DG22E, 21DK24E, 21DK24E1, 21DK24U, 21DP210G, 21DU21C, 21DU21E, 21DU22C, 21DU22E, 21DU24E, 21DX210S, 21DX25E, 21DX25EA, 21DX25ES, 21MT21E, 21MT22E, 24WK21E, 24WK22E, 24WK24E, 24WK25EG, 24WT25E, 25DG16E, 25DG16ET, 25DG17KG, 25DG21E, 25DG22E, 25DG25EG, 25DG25ES, 25DH21E, 25DH22E, 25DT21E, 25DT22E, 25DU21E, 25DU24E, 25DX210S, 25DX25ES, 25DX25KG, 25DX25KH, 25MH21E, 25MN16ET, 28DF21E, 28DF22E, 28DG16E, 28DG16ET, 28DG21E, 28DG22E, 28DG23K, 28DG24E, 28DK24E, 28DK25E, 28DK25ES, 28DK26ED, 28DN20E, 28DN22E, 28DP25EG, 28DP25ES, 28DT21E, 28DT22E, 28EX22E, 28VK24U, 28VK25E, 28VK25EG, 28VK25ES, 28VK26UW, 28WD210S, 28WF25E, 28WF25EG, 28WF25ES, 28WH200S, 28WN22E, 28WR23EG, 28WS21E, 28WS22E, 28WS24E, 28WS26EW, 28WT25ES, 28WT25ST, 28WX210S, 28WZ210S, 29DF25EB, 29DF25EG, 29DF25EL, 29DF25ER, 29DF25ES, 29DF25KG, 29DF25KH, 29DH21E, 29DH22E, 29DJ24E, 29DJ25EG, 29DL200G, 29DL21E, 29DL22C, 29DL22E, 29DL24E, 29DL25ED, 29DU21E, 29DU22E, 29DX210KH, 29DX210KP, 29DX210S, 29DX25ES, 29DZ210S, 29MH21E, 29MH22E, 32VK24U, 32VK25E, 32VK25EG, 32VK25ES, 32WF200G, 32WF25E, 32WF25EG, 32WF25ES, 32WH210S, 32WN22E, 32WS21E, 32WS23E, 32WS24E, 32WS26EW, 32WS26NW, 32WT210S, 32WX210S, 33MF22E, 33MF22EG, 33MS21E, 33MS24E, 33MS24EG, 33MS25UD
Клоны: Brandt 70210S2, 70W212S / Ferguson M8422U, W7022U / Saba M5518C, M5518E, M6322C, M7022E, M8521E, M8522C, M8522E, T7022C, W7021E, W7022E / Telefunken DF222C, DF316ET, DF316ET2, DF322C, DF322E, DF416ET, DF416ET2, DF422E, DS521E, DS521EF, DS522EF, MF222C, MF622E ........... СХЕМА TV Thomson 28DG23K шасси ICC17 (4.89 MB) СХЕМА шасси ICC17 (0.64 MB) ПРОШИВКА на шасси ICC17 ВХОД В СЕРВИСНОЕ МЕНЮ СОСТАВ ШАССИ: Micom - 92R195B9Q0/JAM Memory - 24C16 6 (SMD) EPROM - S031638 Thomson ICC17/ALL SMPS - TS3702C & BUW1215 SAW - K6282K & даташит на K9650M TR Chopper - RR5 40322-98 10537860 Reset & Reg - даташит на TDA8139 Video - TDA8855H Vertical - даташит на TDA8351 Sound - TDA7269 Stereo - MSP34116 A2 ? Tuner - CTF5510A 21130310 Tube - A68ELA011X001 FBT - 40330-68 10781320 (HR8846) / 40330-66 (HR80066) ? / 40330-54 HR8549 HOT - BUH516TH RGB Amp. - TDA6107JF Пульт: - RCT-2100 IC remote - M21007210 RCCreator - 042231B0E33576C7947 ТЕМЫ С НЕИСПРАВНОСТЯМИ: Поиски схемы 27 ошибка 27 ошибка, узкая полоса Не включается из дежурки Замена ТДКС Беспрестанно мигает красный светодиод Глюки управления Нет строчных импульсов "Перезагружается" Невозможно войти в сервис Проблема с изображением |
