imran khan
Иван Зенин
Defect of the LCD panel. Not repaired.
ДОБАВЛЕНО 11/11/2014 20:45
You can try to cut off signals SKV1, SKV2, SKV3, SKVB1, SKVB2, SKVB3, STVP
And Fill the composition of the TV. |
imran khan
Thanks for help i will try to cut these lins |
imran khan
Not working |
imran khan
I cuts those lines but problem still remain the same. |
Borek
Иван Зенин Цитата: | Defect of the LCD panel. Not repaired. |
imran khan
Thanks all of you friends
Problem solved when i install used working panel from local market.
Mark as Solved. |
