SONY BDV-IT1000 американец -- мультизонировать.
SPEKTR11
15/04/2010 05:02
Привезли аппарат в подарок - хотелось бы мультизонировать.
A-SERVICE
15/04/2010 09:34
SPEKTR11 писал:
Эта марка беспроводного адаптера в комплекте домашнего театра.
Может это все таки дом.театр BDV-IT1000 ???
http://www.sony.ru/product/hch-systems-with-blu-ray-disc/bdv-it1000/tab/technicalspecs
улыбка
SPEKTR11
15/04/2010 13:01
A-SERVICE, Да вы правы . Поторопился на радостях и не те буковки вбил, извиняюсь. Исправляю.
serp1972
15/04/2010 14:25
пробуй так --- http://www.videohelp.com/dvdhacks?dvdplayer=SONY+BDV-IT1000&hits=50&Search=Search Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S360 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
This worked for me, but obviously I accept no liability for anyone who tries it on their machine.
A-SERVICE
15/04/2010 17:50
SPEKTR11 писал:
Вообщем похоже придется смотреть тебе только диски американские и канадские.
Суть в чем. Это аппарат с блю рей. Делаются они тяжело.
Причем у тебя не просто аппарат. У тебя аппарат заточенный под только систему NTSC как программно так и аппаратно. И то что предлагает попробовать serp1972 тут не прокатит и плюс еще если бы и прокатило это только для чтения dvd фильмов.
Вообщем делается (обходится как прошивка как и сборка) это с помощью установки специальной МОД-платы внутрь аппарата. См фото- . Это примерно тоже самое как установка MOD-BO-4 в консоли из США или КАНАДЫ версий SCPH-70001 U\C, SCPH-75001 U\C, SCPH-77001 U\C, SCPH-79001 U\C, SCPH-90001 U\C, SCPH-70012 U\C. Они тоже ДО вмешательства проигрывают игры только NTSC, а ПОСЛЕ вмешательства и NTSC и PAL.
Вообщем надо во-первых купить эту плату и по Инструкции установить внутрь аппарата. Стоит эта плата 100 Евро + шиппинг.
Такие платы есть уже в продаже но, поддерживают только
для блю рей дисков страны А и В а для dvd дисков только
регион 1 и 2. При этом переключение происходит в ручную.
Пример:
Technical details:
Modification for: Sony BDP-S2000
Supported DVD regions: 1.2
Automatic region switch: No
Region manually switchable: Yes
Future Firmware Update proof: Yes
UOP skip (intro skip): No
RCE proof for DVD region: 1.2
Multisystem output PAL and NTSC: Yes
Blu-ray Multi-Zone Specifications:
Supported Blu-ray zones: A.B
Automatic BR zone switch: No
BR zone manually switchable: Yes
SPEKTR11
16/04/2010 06:47
A-SERVICE, Cпасибо за исчерпывающую информацию. Радость как-то упала на 0, т. к. ни плату ,ни диски у нас пока недоступны. Буду использовать ,частично ,как экспонат. Спасибо всем . Тему закрываю.
