Panasonic SA-DM3 мультизона
yang
04/11/2007 01:36
Panasonic SA-DM3 с 2 регионом.Есть ли возможность перевести в мультизону с пульта ?
pyjov
08/02/2010 14:41
Попробуй это:
1. Turn on player with no disc inserted
2. While pressing "Shift" on the remote press "Setup"
3. Press "Enter" twice
4. Move the cursor to "Other" and enter the appropriate four-digit region setting, beginning with 000.
5. Press "Enter"
6. Press "Return" twice
7. Switch unit off for at least 3 seconds.
8. Load DVD and play!
ДОБАВЛЕНО 08/02/2010 16:10
If remote does not have a "SETUP" button:
In Step 2, try pressing "Shift" and "Action" buttons in the absence of a "Set-Up" button. Will have the same effect.
For Step 4, select "Other" to 0000 for a multi-regional setting.
