Mikhail
Подскажите пожалуйста способ изменения кода региона
для DUAL DECK SAMSUNG DVD/VCR MODEL NO: SV-DVD1EA.
Посмотрел рекомендованные ранее на форуме адреса, но най-
ти решения не удалось.Если кто-то сможет помочь, то заранее
благодарю. |
Cogur
1. Power on your player
2. Press and hold both the PLAY/PAUSE and FASTFORWARD buttons on the player
3. After a short while you should be presented with a set of language options.
Release the PLAY/PAUSE and FASTFORWARD buttons on the player
4. You will now need to select a language option between 1 and 6
5. Press the SETUP button and then the REPEAT button on your remote control
6. Using your remote control enter the code below, note that you must know
what Region your player is currently set to in order to know which code is
appropriate,
for Region 1 use 2, 9, 3, 3 and 4
for Region 2 use 3, 8, 7, 6 and 7
for Region 3 use 5, 6, 7, 3 and 2
for Region 4 use 7, 6, 8, 8 and 4
for Region 5 use 5, 3, 8, 1 and 4
for Region 6 use 2, 4, 4, 6 and 2
7. A code should be displayed on the upper left corner of the screen indicating
the current Region setting of your unit.
8. Press the 9 button on your remote control for Region free, or 1 for Region 1,
2 for Region 2 and so on.
9. Press the OPEN button on your player
10. Press the STANDBY button on your remote control |
Mikhail
| Спасибо за ответ,но этот вариант только для плеера Samsung SV-DVD1E без А и не для комби.Нужно что то другое. |
Cogur
| сам делал на двойке. Все сработало. |
