DVD плеер Sony DVP-S7000 - 5 зона нужна
Basiloff
Сообщение #1 от 03/03/2005 19:52 цитата
помогите советом / прошивкой .
Заранее благодарен.
scooters
Старательный ученик
scooters
Сообщение #2 от 04/03/2005 18:50 цитата
Есть вот что но сам не пробывал
  Sony DVP-S3000,7000.rar  6.26 КБ  Скачано: 632 раз(а)
Мираж
Меломан
Мираж
Сообщение #3 от 04/03/2005 20:35 цитата
scooters, файл повреждён
Rottor
Сообщение #4 от 04/03/2005 21:26 цитата
Все открывается, и выглядит так:
The Ultimate DVD Upgrade S7000
Sony DVP-S3000 & DVP-S7000 DVD MOD Kit Manual
Macrovision disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] default Players default region
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[0] [AUDIO CHANGE] Automatic region switching OFF
[0] [ANGLE CHANGE] default Automatic region switching ON
[1] [AUDIO CHANGE] Video interference impulses ON (Macrovision ON)
[1] [ANGLE CHANGE] default Video interference impulses OFF (Macrovision OFF)
[2] [AUDIO CHANGE] User operation prohibitions* and Access Restrictions ON
[2] [ANGLE CHANGE] default User operation prohibitions* and Access restrictions OFF
[3] [AUDIO CHANGE] Sync on Green
[3] [ANGLE CHANGE] default Sync on Video
[4] [AUDIO CHANGE] IRE 7.5
[4] [ANGLE CHANGE] IRE 0.0
[4] [SUBTITLE CHANGE] default IRE default
[5] [AUDIO CHANGE] RGB
[5] [ANGLE CHANGE] YUV
[5] [SUBTITLE CHANGE] default RGB/YUV default
The selected region code is unfortunately not visible in the Service Menu.
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angleswitch.
„Play Limited/Play Impossible“
If this error message should appear:
- enter the setup of your player
- go to parental control
- enter the password 1234
- set parental control level to something else
- leave the setup
- power off
- power on
- set parental control level to off
- power off
- power on
Your player does no longer display the message above now!
Profyguy
Сообщение #5 от 05/03/2005 02:46 цитата
Сомневаюсь, что это поможет, т.к. это
...MOD Kit...
Иными словами, это инструкция по пользованию МОДЕРНИЗИРОВАННЫМ с помощью MOD Kit аппаратом. MOD Kit обычно включает в себя микруху с указаниями, как ее подключить. А вот где это Kit купить, похоже, никто толком не знает. Нет недовольство, огорчение
BBKuser
BBKuser
Сообщение #6 от 06/03/2005 23:32 цитата
И будет Вам-счастье http://www.brouhaha.com/~eric/video/dvd/sony_dvp_s7000/#switches улыбка
A-SERVICE
Сообщение #7 от 17/04/2005 14:46 цитата
Инфо- искать по Инету- бесполезно.Эти аппараты делаются, но с применением аппаратных средств.
То есть с применением спец-оборудования. Аппарат должен попасть в руки мастеру по апгрейду, тот в свою очередь сначала сохраняет заводское не тронутое ПО из микросхем плеера, потом подвергает его воздействию спец-оборудования, если сразу не получится, то опытным путем находит верное решение. В конце концов, если "фокус" не удался, аппарат просто возвращается в исходное состояние (r1) и возвращается обратно клиенту на руки. Но, в данном случае это мало вероятно - аппарат не самый сложный. Главное, что бы он попал на руки тому кто этим занимается давно.
