Samsung SV-DVD240P мультизона
Stelt
Сообщение #1 от 14/10/2005 14:59 цитата
Доброго времени суток!
Подскажите плиз, кто знает, как выставить мультизону на Samsung SV-DVD240P.По этой модели ничего не нашёл ни на форуме ни в нете
Эти способы пробовал не прокатило(хотя они подходят для большинства самсунгов):
Always perform a Cold Start before applying the hack below
1. Power on your player
2. Press and hold both the Play and Stop buttons on the player NB: If the above does not work, then press and hold the Play and Forward buttons on your player instead
3. After a short while the words No Disc should disappear from the onscreen display. Release the Play and Stop buttons on the player
4. In some cases you may now need to turn your player off and then back on
To convert this player to Multi-Region playback
1. Press the Subtitle button on your remote control
2. Press the Repeat button on your remote control NB: If the hack does not work then repeat it WITHOUT performing this step
3. Using your remote control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate for
Region 1 use 2, 9, 3, 3 and 4
Region 2 use 3, 8, 7, 6 and 7
Region 3 use 5, 6, 7, 3 and 2
Region 4 use 7, 6, 8, 8 and 4
Region 5 use 5, 3, 8, 1 and 4
Region 6 use 2, 4, 4, 6 and 2
4. A code should be displayed on the screen indicating the current Region setting of your unit.
5. Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
6. Press the Open button on your player
7. Press the Standby button on your remote control
______________________________________________
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The current region should appear in the top left corner of the on-screen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Subtitle button on your remote control
valdis
Сообщение #2 от 21/10/2005 09:12 цитата
Для начала на пульте нужно нажать кнопку "DVD" , дальше по варианту №2, только код набирать в соответствии с родной зоной (из варианта №1).Для аппарата 2-й зоны пробовать коды из обоих вариантов.100% должно сработать.
