I accept any study material for designing sources of PC
eletmoraes
06/04/2016 16:41
I am interested in studying and learning to develop power supply circuits pwm sources used in computers and supplies LCD monitors, any educational material is welcome.
JohnK
06/04/2016 16:50
Do you speak Russian?
eletmoraes
06/04/2016 17:44
I'm from Brazil in Porto Alegre, Rio Grande do Sul, I can communicate with you using Google translator in Russian
JohnK
06/04/2016 22:06
Please use Google translator. Describe your problem.
eletmoraes
06/04/2016 23:41
I would only learn to design electric circuit power supply, the same sources ATX computers and source that feeds the LCD monitors.
Я бы только научиться проектировать электроснабжения цепи, одни и те же источники ATX компьютеров и источник, который питает ЖК-мониторов.
JohnK
08/04/2016 07:31
Do you want to learn how to repair the ATX power supplies, LCD monitors. Did I understand you correctly?
eletmoraes
08/04/2016 20:14
ДОБАВЛЕНО 08/04/2016 21:17
fix I already know, would build a new circuit design a power supply circuit knowing the voltage and current need.
levsha
02/05/2016 14:20
Как ремонтировать я уже знаю, хочу создавать новые схемы источников питания с заданными напряжением и током (выхода авт.)
Вот такой бразилец....
