SHARP 66GF-63H Tелик из Англии ?
danail
Сообщение #1 от 17/09/2004 12:08 цитата
У телик нет DK и BG . Tюнер полной . Какое шаси??.Проц. ST10R272LT1
AII Ex
Сообщение #2 от 17/09/2004 13:32 цитата
DA-50W Шасси
SERVICE MODE
The service mode is provided to enable the engineer to correctly set up the receiver to the CRT fitted in the set.
Note that these adjustments may vary from one receiver to another.
To enter the service mode, carry out the following procedure.
1. Connect a test pattern to the antenna terminal.
2. Tune the receiver to this signal.
3. Turn the receiver off using the mains switch.
4. Press volume down and channel up buttons on the
front of the receiver at the same time.
5. Keeping these buttons pressed, turn the mains on.
6. When the set starts up it will be in service mode.
7. Release the two buttons.
Use the channel up and down buttons to move between the options.
Use the volume control buttons to change the data.
To store the data, use the stand-by button on the remote control.
To exit the service mode, turn the receiver off using the mains switch.
When the service mode is entered the following On Screen Display appears
-SERVICE SOFTWARE AND HEXADECIMAL COUNTER DISPLAY:
SW ON XXXX SW OFF XXXX HOURS ON XXXX
The figures displayed in the XXXX locations are hexadecimal representations of the number of times that particular
function has been executed. For example if the hexadecimal number displayed after SW ON was 0E4A, this would
correspond to the receiver being turned on 3658 times.
Добавлено 17-09-2004 14:32
DA-50W Шасси
SERVICE MODE
danail
Сообщение #3 от 17/09/2004 13:58 цитата
Какие опции нада изменит в сервис за BG / DK
danail
Сообщение #4 от 18/09/2004 16:31 цитата
помогите!!!
AlexM
AlexM
Сообщение #5 от 18/09/2004 21:12 цитата
danail писал:
Никакие , ставьте конвертер
или ищите прошивку ROM от 70GF63Е. Может получится, у меня нет этой прошивки.
Нашёл какую-то если есть желание попробуйте, но необходимо предварительно сохранить прошивку NVM и проинициализировать сновой ROM.
  70GF66E-E602-x03.zip  329.9 КБ  Скачано: 417 раз(а)
Вано
Сообщение #6 от 18/09/2004 21:39 цитата
AlexM Я не понял примочку нада а не конвертор.......... звук то 6.0................................................
andyli
Сообщение #7 от 18/09/2004 21:52 цитата
попробуй заменить в конверторе выходной фильтр 5.5 на 6.0 -ставь и подстрой выходной контур в конверторе.
AlexM
AlexM
Сообщение #8 от 18/09/2004 22:37 цитата
Вано писал:
Я тоже не понял . Что есть
примочка
Я ставил конвертер 6.0 в 6.5 гетеродин 500 кГц. на пьезо фильтре.
