сервис режим? Филипс 29pt8508/12
загдай
Сообщение #1 от 21/10/2006 15:40 цитата
Как зайти в сервис режим? улыбка Филипс 29pt8508/12
k3048
Сообщение #2 от 21/10/2006 22:26 цитата
chassis EM2E
http://master-tv.com/proshivki/tv/Philips-eeprom-memory-dump.html
062596info -->SAM
062596 menu -->SDM
ALIGNEMENTS:
GENERAL:
Drive:
test pattern -> OFF
red -> 35
green -> 35
blue -> 35
cathode -> 3
red BL offset -> 7
green BL offset -> 7
tint -> NORMAL
Luminance Delays:
lum. delay pal -> 7
lum. delay secam -> 11
lum. delay bypass -> 10
EHT compression -> 0
Soft clipper -> Pwl + 0%
Luma gain -> 1
IF AFC -> 30
Tuner AGC -> 20
Blend intensity -> 16
Adjust peak white limiter-> 11
Vg2 Test Pattern -> OFF
NORMAL GEOMETRY:
Test pattern -> OFF
V slope -> 50
H shift -> 33
H amplitude -> 43
East/West Parabola -> 25
Upper East/West corner -> 41
Lower East/West cornel -> 45
East/West Trapezium-> 29
Horizontal parallalogram -> 8
Horizontal bow -> 8
OPTIONS:
Dual screen PIP:
Aux type -> NONE
Teletext/EPG:
TXT -> YES
NexTView present -> YES
NexTView type -> No flashram
Comunication:
Easylink Plus -> YES
Picture Tube:
CRT Type -> 4:3
Dynamic focus -> YES
Dooming prevent -> OFF
Bass corection -> Other
Video repro:
Featurebox type -> Prozonic
Light sensor -> NO
Pal plus -> No
Combfilter -> NO
Picture improvement-> No
Picnic AGC -> YES
Signaling bits -> YES
Vertical squeeze -> YES
Source selektion:
External 3 -> NO
External 4 -> NO
Audio Repro:
Dolby -> NONE
Acoustic system -> F17
MSP type -> MSP3415
AVL enable -> ON
Miscellaneous:
Heatsink Present -> YES
Tuner type -> UV1316
TXT sync L edge -> YES
OPTIONS NUMBER:
21393 04352 01024 00016
04215 00001 00000 00065
INITIALIZE NVM ->
STORE ->
DEALER OPTIONS:
PICTURE:
Cti -> YES
PERSONAL:
Blue Mute -> YES
Virgin Mode -> YES
Auto Store Mode -> PDC-VPS-TXT
Demo Menu Enable -> YES
Auto TV -> YES
TELETEXT:
Txt preference -> FLOF
East/West Txt -> EAST
STORE -> zapamiętanie ustawień menu DEALER
