imran khan
PHILIPS L01.1
Symptom
The set goes into protection. Cure
Because the output voltage of the
power supply unit is 130V instead of
140V, The set is going into protection
due too high gain of IC7515.
Check and if necessary replace position 6541 on the Mono Carrier [A]
by BZX384-C9V1 (9322 150 08685). REMARKS :
Introduced in production from week 245 onwards.
ДОБАВЛЕНО 15/02/2013 02:34
L01.1A Symptom
A few seconds after start up the TV Set
shuts down into stby. Cure
Check and if necessary replace C2563
(100nF) in the power supply by 4822
121 41689. In normal operation the
base at transistor T7561 measures
-3,2V, in fault condition 0V. --------------------------------------------------------------------------------------
ДОБАВЛЕНО 15/02/2013 02:36
L01.1
Symptom
Set switches off and on again at preset
1 while changing channel Cure
Only valid for sets with 1PAGE TXT L01.1E: Check and if necessary replace
position 7200 by
TDA9555_L01ET51.8 (9352 725
45557) L01.2E: Check and if necessary replace
position 7200 by
TDA9552_L01ET51.8 (9352 725
44557) REMARKS :
All the previous software versions
L01ET5/L01ET0/L01ET9 have this
problem and may not be used.
ДОБАВЛЕНО 15/02/2013 02:38
Symptom
TV set goes into protection after 15
seconds Cure
Re-adjust the VG2 tension according
to section 8.2.1 of the Service Manuals
L01.1E AA L01.1A AA L01.1L AA
Symptom
TV set not operating, no red front LED. Cure
1) Measure the drive pulse on pin 6 of
IC7520 (TEA1507).
2) If no drive pulse present, check the
voltage on pin 1: must be >= 11 V.
3) If this voltage is < 11 V, check/ replace capacitor C2526 (order code:
4822 126 13482, 470nF/
+80-20%/16V/Y5V/0805).
ДОБАВЛЕНО 15/02/2013 02:40
Symptom
TV in protection due to bad 200V Cure
IC7330 on the Picture Tube Panel
defective due to flashes from picture
tube to the heatsink.
Replace the heatsink item 0118 on
Picture Tube Panel [B1] by 3139 121 26731 (3.0x4.0cm) REMARKS : Introduced in production
from week 129 onwards
ДОБАВЛЕНО 15/02/2013 02:42
Symptom
Power supply relay is switching
permanently Cure
Check and replace if nessecary item
3408 (1k) on the Mono carrier [A] by
10k (4822 050 21003) REMARKS : Introduced in production in
week 141 -------------------------------------------------------------------------------------- Symptom
TV does not start while it is cold Cure
10k (4822 050 21003) REMARKS :Introduced in production in
week 141
ДОБАВЛЕНО 15/02/2013 02:43
Symptom
A few secondes after start up the TV
Set shuts down into stby. Cure
Check and if neccesary replace C2563
ДОБАВЛЕНО 15/02/2013 02:44
Symptom
245 onwards.
ДОБАВЛЕНО 15/02/2013 02:45
Symptom
TV set starts up and immediately
switches to protection mode. Cure
Check and if necessary replace diode
6467 for L01.1E and diode 6406
for L01.2E (5322 130 34331) on the
Mono Carrier A.
ДОБАВЛЕНО 15/02/2013 02:47
Symptom
TV set doesnot start up. Cure
Check and if necessary replace on the
Mono Carrier [A]:
- Capacitor 2405 (5322 126 10511)
- Resistor 3493 for L01.1E and resistor
3404 for L01.2E (4822 052 10688) - Diode 6467 for L01.1E and diode
6406 for L01.2E (5322 130 34331). |
Бакум
Рождённый в СССР
БЛАДЬ!!!!!! imran khan, Ты можешь хоть сюда не лезть!!!!! Ты на своем форуме достал наверное всех, решил и здесь...... иди на монитор , ссылку дать или ты ее знаешь |
iv-9
bakum, он так весь сайт своим кривым инглишем засерет Проще самому додуматься, чем по его перлам На зеркале есть кнопочка предупреждения за флуд, нарушение правил и т.п., и баны за это, а здесь - воля |
bakum писал: | иди на монитор | - он СЮДА - ОТТУДА ... |
Бакум
Рождённый в СССР
Руслан а как вы его сюда? поделись |
LordLostr
KRAB писал: | он СЮДА - ОТТУДА ... |
bakum писал: | Руслан а как вы его сюда? поделись |
Есть и другие форумы,где много мастеров. |
viktor_ramb
Сам себе начальник
bakum, Цитата: | БЛАДЬ!!!!!! imran khan, Ты можешь хоть сюда не лезть!!!!! Ты на своем форуме достал наверное всех, решил и здесь...... иди на монитор , ссылку дать или ты ее знаешь. |
Игорь! Первое слово ТС точно не поймёти не переведёт правильно! Просто интересно - это его случаи ремонта Филипков или он с инета скопипастил, что бы здесь втереться? |
JYRIJJ
Спец-агент
KRAB писал: | bakum писал: | иди на монитор | - он СЮДА - ОТТУДА ... | Да нет! Там уже шесть дней, и ничего не написал "Присматривается" |
LordLostr
viktor_ramb писал: | Игорь! Первое слово ТС точно не поймёти не переведёт правильно! |
Это мы легко изложим, доступно для перевода:"Гуляющая женщина". А вот как наш сленг технический?Аббревеатуру? Да и его перлы,пробовал перевести,ни хрена не понял.Остаётся: либо нам английский учить,либо ему русский. |
Alexasha
viktor_ramb писал: | Просто интересно - это его случаи ремонта Филипков |
Какие нахер ремонты... Пакистан.
LordLostr
Alexasha
LordLostr писал: | http://pashaman.livejournal.com/522871.html |
забрал в коллекцию IP? |
