Ищу дамп edimax ic-3115w
  Список форумов » Прошивки
Popadinets
Сообщение #1 от 31/01/2019 02:42 цитата
edimax ic-3115w- ip камера
не загружается (на несколько секунд загораются светодиоды)
RTL8196C+ MX25L3206E
слитый дамп и логи во вложении
Код:
Booting...
========== SPI =============
---RealTek(RTL8196C)at 2012.06.27-10:32+0800 version v1.1f [16bit](390MHz)
no sys signature at 00020000!
no sys signature at 00030000!
no sys signature at 00011000!
no sys signature at 00012000!
no sys signature at 00013000!
no sys signature at 00014000!
no sys signature at 00015000!
no sys signature at 00016000!
no sys signature at 00017000!
no sys signature at 00018000!
no sys signature at 00019000!
no sys signature at 0001A000!
no sys signature at 0001B000!
no sys signature at 0001C000!
no sys signature at 0001D000!
no sys signature at 0001E000!
no sys signature at 0001F000!
no sys signature at 00021000!
no sys signature at 00022000!
no sys signature at 00023000!
no sys signature at 00024000!
no sys signature at 00025000!
no sys signature at 00026000!
no sys signature at 00027000!
no sys signature at 00028000!
no sys signature at 00029000!
no sys signature at 0002A000!
no sys signature at 0002B000!
no sys signature at 0002C000!
no sys signature at 0002D000!
no sys signature at 0002E000!
no sys signature at 0002F000!
no sys signature at 00031000!
no sys signature at 00032000!
no sys signature at 00033000!
no sys signature at 00034000!
no sys signature at 00035000!
no sys signature at 00036000!
no sys signature at 00037000!
no sys signature at 00038000!
no sys signature at 00039000!
no sys signature at 0003A000!
no sys signature at 0003B000!
no sys signature at 0003C000!
no sys signature at 0003D000!
no sys signature at 0003E000!
no sys signature at 0003F000!
no sys signature at 00040000!
Set 8196C PHY Patch OK
---Ethernet init Okay!
<RealTek>
  mx25l3206e.rar  3.27 МБ  Скачано: 96 раз(а)
Popadinets
Сообщение #2 от 04/02/2019 19:08 цитата
Слепил, может кому пригодится - улыбка
  IC-3115W_v2.03_damp.rar  3.27 МБ  Скачано: 102 раз(а)
jilativ
Сообщение #3 от 24/11/2019 16:09 цитата
Popadinets писал:
Добрый день. Есть камера ic-3140, почти то-же самое. И проблема такая-же. Перезагружается. Подскажите как слепить из слитого дампа и прошивки с оф сайта свой рабочий дамп. Как Вы его делали? Прикрепил кусок лога где происходит сбой. Если кто может помочь собрать дамп, выложу и слитый с флешки с проблемой.
Код:
Freeing unused kernel memory: 108k freed
usb 1-1: configuration #1 chosen from 1 choice
CPU 0 Unable to handle kernel paging request at virtual address c0021fff, epc == 800f0d28, ra == 800f0814
Oops[#1]:
Cpu 0
$ 0   : 00000000 10000400 c0021fff 0ef321fe
$ 4   : 00000001 0ef321fd 00000000 7ffffc00
$ 8   : 00000000 81000000 81063658 00000000
$12   : 803a590c 00080000 00080000 80315c90
$16   : 00000000 00000009 c0022000 c0080000
$20   : 00000001 8381bb1c 00000000 01000000
$24   : 00000002 8003f498
$28   : 83818000 8381baf0 00000001 800f0814
Hi    : 00000000
Lo    : 10000000
epc   : 800f0d28 0x800f0d28
    Not tainted
ra    : 800f0814 0x800f0814
Status: 10000404    IEp
Cause : 40000008
BadVA : c0021fff
PrId  : 0000dc02 (<NULL>)
Modules linked in:
Process init (pid: 1, threadinfo=83818000, task=83814c70, tls=00000000)
Stack : 00000020 800060f8 00000000 80000420 8381bb88 00000020 8381bb90 c9f10cde
        03f415fa d54f73b4 67000000 800f0408 c0000012 c0000000 c0005c36 00005c36
        0fed3e95 10000000 10000000 7cbef016 00000000 00000001 c0000000 00000000
        00000001 00000003 00000000 00000003 0000000f c0080644 c0080a68 c0080664
        00000005 830b304c 0000000d 8003f498 00000004 80086184 803d0000 830b9700
Call Trace:[<800060f8>] 0x800060f8
[<80000420>] 0x80000420
[<800f0408>] 0x800f0408
[<8003f498>] 0x8003f498
[<80086184>] 0x80086184
[<800a365c>] 0x800a365c
[<80081274>] 0x80081274
[<80081700>] 0x80081700
[<80081b70>] 0x80081b70
[<800a34d8>] 0x800a34d8
[<80112d00>] 0x80112d00
[<8009f2b4>] 0x8009f2b4
[<80204210>] 0x80204210
[<8002aa74>] 0x8002aa74
[<8009fb7c>] 0x8009fb7c
[<800a0cf0>] 0x800a0cf0
[<80043284>] 0x80043284
[<8003cc98>] 0x8003cc98
[<80045cb8>] 0x80045cb8
[<8022ca2c>] 0x8022ca2c
[<80046190>] 0x80046190
[<80006210>] 0x80006210
[<8003ef60>] 0x8003ef60
[<8003a50c>] 0x8003a50c
[<8005e0dc>] 0x8005e0dc
[<8005ee7c>] 0x8005ee7c
[<8005ecc8>] 0x8005ecc8
[<8005ed18>] 0x8005ed18
[<80001330>] 0x80001330
Code: 00431021  00431023  02421021 <90430000> 02501021  26100001  12c00171  a0430000  8ba2001d
Disabling lock debugging due to kernel taint
Booting...
Загрузчик живой. Есть програматор, слил бекап с микросхемы 25LMX6405D. На сайте производителя есть прошивка но, похоже, она только для заливки с web фейса.
Если останавливаю автозагрузку (нажатием Esc в начале загрузки) то на команду "?" реагирует.
Код:
---RealTek(RTL8196D)at 2014.07.22-19:57+0800 v0.3 [16bit](700MHz)
P0phymode=01, embedded phy
<RealTek>?
----------------- COMMAND MODE HELP ------------------
HELP (?)                                    : Print this help message
DB <Address> <Len>
DW <Address> <Len>
EB <Address> <Value1> <Value2>...
EW <Address> <Value1> <Value2>...
CMP: CMP <dst><src><length>
IPCONFIG:<TargetAddress>
AUTOBURN: 0/1
LOADADDR: <Load Address>
J: Jump to <TargetAddress>
FLR: FLR <dst><src><length>
FLW <dst_ROM_offset><src_RAM_addr><length_Byte> <SPI cnt#>: Write offset-data to SPI from RAM
MDIOR:  MDIOR <phyid> <reg>
MDIOW:  MDIOW <phyid> <reg> <data>
PHYR: PHYR <PHYID><reg>
PHYW: PHYW <PHYID><reg><data>
PORT1: port 1 patch for FT2
DRAMTEST <R/W> <enable_random_delay> <PowerManagementMode>
TR <rx_shitf> <tx_shitf>
WPS: 0
Reset: 1
WAKE_or_PIR_IC-3040: 1
LightSensor_IC-3040: 1
RTL_GPIO_MUX:   0x00000006
RTL_GPIO_MUX2:  0x00100000
PABCDCNR_REG:   0xfffe9bf7
PABCDDIR_REG:   0xff014400
PABCDDAT_REG:   0x0001005c
PEFGHCNR_REG:   0x00d4ffff
PEFGHDIR_REG:   0x00090000
PEFGHDAT_REG:   0x00000000
<RealTek>
jilativ
Сообщение #4 от 27/11/2019 14:57 цитата
Свою таки восстановил. Вот ссылка на тему http://monitor.espec.ws/section26/post2489138.html#2489138
Другие темы раздела Прошивки
