DC/DC преобразователи в корпусе QFN / DFN
Yuritsh
19/10/2012 20:56
DC/DC преобразователи в корпусе QFN / DFN . . . .
A4490 - (4x4mm QFN20 Package) - SMD marking code xxxx
AOZ1014DI - (4x5mm DFN8 Package) - SMD marking code xxxx
AX3503 - (2x2mm TDFN6 Package) - SMD marking code Ga / Gc
AX3512 - (2x2mm TDFN6 Package) - SMD marking code G9xx
FAN2365 - (5,5x5mm PQFN34 Package) - SMD marking code xxxx
HX1106 - (3x3mm DFN10L Package) - SMD marking code HXN-HE
IR3475 - (4x5mm QFN16 Package) - SMD marking code 3475
IR3856WM - (4x5mm QFN16 Package) - SMD marking code xxxx
ISL8201M - (15x15mm QFN15 Package) - SMD marking code xxxx
LT1933 - (2x3mm DFN6 Package) - SMD marking code LCGM / LCGN
LT3463 LT3463A - (3x3mm DFN10 Package) - SMD marking code xxxx
LT3472 - (3x3mm DFN10 Package) - SMD marking code xxxx
LT3502 LT3502A - (2x2mm DFN8 Package) - SMD marking code xxxx
LTC3100 - (3x3mm QFN16 Package) - SMD marking code xxxx
LTC3105 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3255 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3411 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3427 - (2x2mm DFN6 Package) - SMD marking code xxxx
LTC3428 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3526 LTC3526B - (2x2mm DFN6 Package) - SMD marking code xxxx
LTC3530 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3532 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3537 - (3x3mm QFN16 Package) - SMD marking code xxxx
LTC3568 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3605A - (4x4mm QFN24 Package) - SMD marking code xxxx
LTC3614 - (3x5mm QFN24 Package) - SMD marking code xxxx
LTC3805 - (3x3mm DFN10 Package) - SMD marking code xxxx
LTC3805-5 - (3x3mm DFN10 Package) - SMD marking code xxxx
MAX8667 MAX8668 - (3x3mm QFN16 Package) - SMD marking code AEQ AFI AFM AFN
MCP16321 MCP16322 - (3x3mm QFN16 Package) - SMD marking code AAA AAB AAC AAD AAE AAF ABA ABB ABC ABD ABE ABF
MP2119 - (3x3mm QFN10 Package) - SMD marking code U8
MP2205A - (3x4mm QFN14 Package) - SMD marking code MP2205A
MP2212 - (3x3mm QFN10 Package) - SMD marking code Z7
MP28128 - (3x3mm QFN10 Package) - SMD marking code xxxx
OCP2182 - (3x3mm DFN10 Package) - SMD marking code xxxx
PAM2309 - (2x2mm DFN6 / 3x3mm QFN16 Package) - SMD marking code BLxxx / P2309x
RT8010 - (2x2mm WDFN6L Package) - SMD marking code xxxx
RT8010A - (3x3mm WQFN16L Package) - SMD marking code xxxx
RT8057A - (2x2mm WDFN-6SL Package) - SMD marking code xxxx
RT9276 - (3x3mm WDFN10L Package) - SMD marking code EW=xx
SC189 - (2x2mm MLPD-UT6 Package) - SMD marking code FLx
Si3500 - (5x5mm QFN20 Package) - SMD marking code xxxx
ST1S10 - (4x4mm DFN8 Package) - SMD marking code xxxx
ST8R00 - (4x4mm DFN8 Package) - SMD marking code xxxx
TPS54620 - (3,5x3,5mm QFN14 Package) - SMD marking code xxxx
TPS61030 TPS61031 TPS61032 - (4x4mm QFN16 Package) - SMD marking code xxxx
TPS63000 TPS63001 TPS63002 - (3x3mm DRC10 Package) - SMD marking code BPT BPU BPV
TPS63020 TPS63021 - (3x4mm QFN14 Package) - SMD marking code xxxx
TPS63700 - (3x3mm SON10 Package) - SMD marking code NUB
UM3501DA - (2x2mm DFN6 Package) - SMD marking code AAEx
ZL6105 - (6x6mm QFN36 Package) - SMD marking code xxxx
