TV repair Samsung LE32M87BD chassis GTU32HEN, problem DC / D
imran khan
15/01/2013 12:58
chassis GTU32HEN, problem DC / DC
Description of the Problem When the standby LED will flash,
sounds musical screensaver, but the
light does not appear, the TV starts a
new attempt to start and this goes on for about 3 minutes. At some point,
begins to work inverter and a picture of this type: Visually "bloated" capacitors in the power supply is not visible. Output
voltages correspond to the scheme,
the control pulses of crime is not
revealed.
Composition chassis GTU32HEN: MAIN: BN63-02494A
Tuner: DN0S403MH26
SGTV5810C
BA7657F
T-CON: T315XW02 VF
PSU: BN44-00156B MC33067P
STR-A6159
INVERTOR: T315XW02 VF
F10V0411-01
SUB BOARD: BN41-00895B
BN94-01382B Nature of the problem has changed
over time, which has led to the
assumption of the capacitive nature of the defect. The first were tested DC / DC converters MAIN Board, but their voltage match circuit. Wings on the board defect Submodule SUB Board: S6108_FRC was faulty capacitor in a DC / DC on board BN41-00895B: Was discovered by unsustainable ripple 3 pin. IC6007 L4931CDT33,
nominal 1 uF. Repair has been reduced to the
replacement of the component. The
efficiency of the TV recovered after
replacement. Perhaps the service manual for this model will be useful in the repair of Samsung televisions in the chassis GTU32HEN
vebs
15/01/2013 15:41
imran khan, сколько эта твоя хрень с не русским языком будет продолжаться?
Ты типа не уважаешь русский? Тогда шагай на английский форум! В чужом монастыре со своими правилами?
Скачай прогу переводчика и переводи, прежде чем тут писать. Думайте сами ...
Торгаш !!! http://translate.google.ru/translate?hl=ru&sl=en&u=http://lcddata.webs.com/&prev=/search%3Fq%3Dimran_usa9%2540yahoo.com%26hl%3Dru%26newwindow%3D1%26tbo%3Dd%26biw%3D800%26bih%3D503&sa=X&ei=wE71UMO9D8WUswa3zoHICA&sqi=2&ved=0CFoQ7gEwBQ
Раз продаешь инфу по ремонту, так не лезь на бесплатный русскоязычный форум мастеров, со своим английским форматом.
УЧИСЬ УВАЖАТЬ ЛЮДЕЙ , К КОТОРЫМ ПРИШЕЛ!
imran khan
15/01/2013 16:32
I dont want to hurt you people any more.
vebs
15/01/2013 16:39
Vais au bains avec l'anglais! Думайте сами ...
snoopy
15/01/2013 17:00
vebs писал:
vebs, Извини, но ты неправ! подмигивание 9. Писать сообщения разрешается только на русском или английском языках. В первом случае в качестве набора знаков должна использоваться кириллица, во втором - латиница. Если у вас нет возможности писать на кириллице, но вы хотите оставить сообщение на русском языке, используйте функцию "Русская клавиатура".
http://monitor.espec.ws/info/rules.html
vebs
15/01/2013 17:09
snoopy, заполню создам пару тем на английском. Будешь читать? Правила правилами , а я писал про УВАЖЕНИЕ! И потом, он темы создает не с вопросами а с решениями. А что там в правилах написано? Его нужно перемещать в Энциклопедию.Раз уж правила ты так соблюдаешь ,то переноси темы куда нужно http://monitor.espec.ws/section31/topic122783.html
snoopy писал:
Все у него есть. Издевается и не более.
imran khan писал:
Уважаемые участники форума, я
хочу узнать от вас людей, а также
поделиться тем, что я есть классно!
МЕДАЛЬ ЕМУ дай! смех За то что один ...по правилам пишет на английском, а десятки ребят потом трахаются с переводчиками.
Yuritsh
15/01/2013 17:26
vebs, не наезжай на человека. Он тебе не конкурент.
vebs
15/01/2013 17:28
Yuritsh, улыбка ты про ТС? Устал переводить его темы. Может он там пишет хрень антисимисткую. А я как порядочный гражданин должен быть бдительным! улыбка
Yuritsh
15/01/2013 17:30
Да.
Если кто-то отвечает на английском, это тоже польза. Попрактиковаться в английском никому не вредно. А не хочешь - не отвечай. Прошел мимо, да и всё.
vebs писал:
За этим есть кому следить.
Я тоже на болгарском форуме по русски спрашивал. Ничего, ответили, не надорвались. И не возмущались.
vebs
15/01/2013 17:37
Сергей.
Ему тогда нужно объяснить куда свои темы девать. Например сюда. http://monitor.espec.ws/section31/topic122783p60.html
Ты прав. Пусть строчит. улыбка
Administrator
15/01/2013 18:15
Сообщение Администрации :
Внимание!
Использование английского языка на форуме разрешено правилами.
Using English on the forum is allowed by the rules.
Nik_Al
15/01/2013 20:53
vebs писал:
imran khan, Скачай прогу переводчика и переводи, прежде чем тут писать. Думайте сами ...
Ладно, так и быть - сделаю это за него улыбка
Ремонт телевизоров Samsung LE32M87BD
Шасси GTU32HEN, проблема DC / DC
Описание проблемы, когда ожидания светодиод будет мигать,
Звучит музыкальная заставка, но
свет не появится, ТВ начинается
Новая попытка начать, и это продолжается в течение примерно 3 минут. В какой-то момент,
начинает работать преобразователь и картины этого типа: Визуально "раздутой" конденсаторы в блоке питания не видно. выходной
напряжения соответствуют схеме,
управляющие импульсы преступления не
выявлено.
Состав шасси GTU32HEN: MAIN: BN63-02494A
Тюнер: DN0S403MH26
SGTV5810C
BA7657F
T-CON: T315XW02 VF
Блок питания: BN44-00156B MC33067P
STR-A6159
ИНВЕРТОР: T315XW02 VF
F10V0411-01
SUB СОВЕТ: BN41-00895B
BN94-01382B Характер проблемы не изменилось
с течением времени, что привело к
Предположение о емкостного характера дефекта. Первые были протестированы DC / DC преобразователи основной плате, но их напряжение холостого хода матча. Крылья на плате субмодуля дефект SUB совет: S6108_FRC был неисправный конденсатор DC / DC на борту BN41-00895B: было обнаружено неустойчивой пульсации 3-контактный разъем. IC6007 L4931CDT33,
номинальная 1 мкФ. Ремонт был сокращен до
Замена компонента.
Эффективность телевизора восстановилась после
замена. Возможно, инструкции по эксплуатации для данной модели будет полезна при ремонте телевизоров Samsung на шасси GTU32HEN
imran khan
16/01/2013 15:19
Thank you admin
imran khan
16/01/2013 16:34
Thanks all who support me
And love you all.
Oleg-44
16/01/2013 17:08
Да вот эта тема, только на русском языке.http://tvrepair.ru/neispravnosti/132-remont-samsung-le32m87bd.html
vebs
16/01/2013 19:36
imran khan писал:
And love you all.
Fsglilgk Iw sdfmn, i asjkfjlo jys? бяка
Бакум
16/01/2013 20:13
Еще одна тучка..... смех
B.B.
17/01/2013 18:02
Administrator писал:
Жаль, что о тупом плагиате ничего не написано в правилах.
Содрал в наглую все с другого сайта и хотябы на аглицком намек на источник. бяка бяка бяка
mehanik.57
30/05/2013 00:14
Ну, разобрались. Когда этот дефект встретился во второй раз, я решил разместить материал о нем на своем сайте http://tvrepair.ru/. Не думал, что буду читать этот текст на английском.
vebs
30/05/2013 06:53
Скоро и на Китайском напишут.
