Можно в место STR X6750 менять на STR X6456
MASTER1111
25/08/2019 02:22
Телек Модель SAMSUNG Model SP-43R1HLR. Code: SP43R1HL1X VERSION-1
Шасси BP41-00245B PWR-DEF
Работает на STR X6750 под рукой сейчас только STR X6456 с другого телек такая же рабочий проекционка
Могу поменять ?
montykit
06/08/2021 14:27
I have a string like this (read from scanning a barcode):
str = val1\^_val2\^_val3\^_
and I want to replace the \^_ with a pipe character (|)
but when I try and do:
str = [str stringByReplacingOccurrencesOfString:@"\^_" withString:@"|"];
..it gives me a warning 'unknown escape sequence '\'^'
Oddly if I just try to replace the ^_ with the | it still doesn't do it. No warning, but the string still has the \^_ between the values.
Can anyone help with what I'm trying to do? If I send the full string to javascript (which I need to), it comes as val1val2val3 and I need them splittable into an array.
