help identify a burned smd fet on hp2105 monitor
  Список форумов » TFT-мониторы
Mohamed Kamel
Сообщение #1 от 26/11/2018 23:18 цитата
Hi
Brought for repair a dead Hp2105 monitor.
Found damaged : fuse F601 +cap C605 + Q651 +R670 +Q655
Need monitor schematic or diagram of the Power supply card 4H.L1S02.A20 to help identify the burned Q655 fet.
Thank you
Mohamed Kamel
Сообщение #2 от 04/12/2018 14:37 цитата
Hi
Urgent help needed for my previous post!
Thank you
skolin
Сообщение #3 от 04/12/2018 17:23 цитата
Look not for the name of the monitor and written on the Board of the power supply
Mohamed Kamel
Сообщение #4 от 05/12/2018 21:50 цитата
skolin писал:
The Monitor is precisely Hp F2105.
On the faulty Power supply card is written as said previously "4H.L1S02.A20".
Any help to identify the burned component should be appreciated.
Many thanks.
