Dell inspiron N5010 erratic shut down
Mohamed Kamel
Сообщение #1 от 25/04/2014 02:07 цитата
Dell inspiron N5010 intel platform has erratic shut down issues, sometimes at P.O.ST screen, others long time after windows login.
Steps already taken :
-Fan cleaned, new paste added for CPU and GPU
-Ram and Hard drive tested ok-
Did anyone experience this situation with N5010 or have any clue as where to dig further ?
A prompt reply should be largely appreciated.
Thank you
JohnK
Комповед
Комповед
JohnK
Сообщение #2 от 25/04/2014 05:12 цитата
Write a post code in which the stop.
Mohamed Kamel
Сообщение #3 от 27/04/2014 18:28 цитата
As mentioned, lap shuts down erratically : either at different stages of post screen or during (or after) logging to windows and that complicates the issue.
Heat is normal
JohnK
Комповед
Комповед
JohnK
Сообщение #4 от 28/04/2014 22:26 цитата
than the temperature measured?
Sergej
Sergej
Сообщение #5 от 29/04/2014 00:32 цитата
Mohamed Kamel, is ME-Region in BIOS clear (new)? Try to translate: http://vlab.su/viewtopic.php?f=181&t=6897
http://vlab.su/viewtopic.php?f=181&t=7012
