HP PAVILLON DV6 with display fail
Mohamed Kamel
Сообщение #1 от 25/04/2014 02:27 цитата
Hi
Hp pavilion Dv6 has neither internal nor external display.
Fan is running, hard drive spinning.
Steps taken :
Tried with only mobo and new ram to no avail.
Is DV6 prone to graphic problem, same as DV 6000-9000...series?
Any suggestion as where to dig further is welcome.
Thank you
Platform : DAOQT8MB6GO REV: G
JohnK
Комповед
Комповед
JohnK
Сообщение #2 от 25/04/2014 05:18 цитата
The operating system boots? If so, change the GPU.
Mohamed Kamel
Сообщение #3 от 27/04/2014 18:42 цитата
Further steps taken : I reflowed GPU and NB and Display came. Will see if it's a momentary or a permanent fix.
JohnK
Комповед
Комповед
JohnK
Сообщение #4 от 28/04/2014 22:24 цитата
it will not work for long. but you vysnilos cause. chip must be replaced.
