EZONETRONICS RM-CT0009 (AC8227)
attack1975
Сообщение #1 от 23/04/2019 19:59 цитата
При включении моргает белым экраном 1 раз, при нажатии ресет тоже, пытаюсь прошить с sd карты в терминале выдает такое:
    ----- AC8317 preloader v66573 -----
    Build Time: Mar 29 2016 11:59:04
    Init SD2 Card
    Send CMD0
    Send CMD1 no response
    Send CMD8
    Send CMD8 unkown
    Send ACMD41
    SD Card Ready
    Send CMD2
    Send CMD3
    card type is 3,RCA is 0x7
    Init SD2 Card Succuss
    eboot_img_des:
    dwLoadAddress:0x8fc60000
    dwLoadPhyAddr:0x06f00000
    dwJumpAddress:0x8fc60000
    dwJumpPhyAddr:0x06f00000
    dwStartAddr:0x00011000
    dwdwTtlLen0x00080000
    dramk , Mar 29 2016 11:59:07
    dram setting version:ac8317 m1v1 v0.0
    DC Balance OFF without Resistance
    Real frequency from PLL is 756 MHz
    DDR3, data rate: 1512 MHz.
    MEMPLL VCOCAL CPLT FLAG = 1; VCO STATE = 7
    MEMPHYPLL A1 VCOCAL CPLT FLAG = 1; VCO STATE = 5
    MEMPHYPLL AB VCOCAL CPLT FLAG = 1; VCO STATE = 5
    MEMCTLPLL VCOCAL CPLT FLAG = 0; VCO STATE = 5
    Support SSC
    set 0xA0[1]=1,0xBC[1]=1
    ========== A1 PLL ==========
    delay tap= 0 DLINE=0 , count= 0 @ confidence=16
    A1 PLL need to scan FBK delay
    delay tap= 1 DLINE=0 , count= 0 @ confidence=16
    delay tap= 2 DLINE=2 , count= 2 @ confidence=16
    A1 PLL calibration done! Final delay is 2
    ========== AB PLL =========
    AB PLL need to scan FBK delay
    delay tap= 1 DLINE=2 , count= 6 @ confidence=16
    AB PLL calibration done!Final delay is 1
    ======== CTL PLL ========
    CTL PLL need to scan FBK delay
    delay tap= 2 DLINE=0 , count= 0 @ confidence=16
    delay tap= 3 DLINE=1 , count=16 @ confidence=16
    CTL PLL calibration done!Final delay is 3
    dramc_write_leveling_swcal
    byte_i status best delay
    0 3 6
    1 3 6
    2 3 0
    3 3 0
    MIOCK jitter meter
    1T = (81-17) = 64 delay cells
    dqs input gating window, best delay value
    best DQS0 Coarse 2T = 5
    best DQS1 Coarse 2T = 5
    best DQS2 Coarse 2T = 5
    best DQS3 Coarse 2T = 5
    _________________________________
    best DQS0 Coarse 0.5T = 2
    best DQS1 Coarse 0.5T = 2
    best DQS2 Coarse 0.5T = 1
    best DQS3 Coarse 0.5T = 1
    best DQS0 fine tune = 1
    best DQS1 fine tune = 1
    best DQS2 fine tune = 25
    best DQS3 fine tune = 27
    Start DQ delay to find pass range, DQS delay fixed to 0...
    x-axis is bit #; y-axis is DQ delay (0~15)
    ooooooooooooooooooooooxooooooooo
    xxooooooooooooooooooooxooooooooo
    xxoxoooooxooooooxooooxxooooooooo
    xxxxxxxoxxxoxxooxxxxxxxoxxooxooo
    xxxxxxxxxxxoxxxoxxxxxxxxxxooxoox
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Start DQS delay to find pass range, DQ delay fixed to 0...
    x-axis is bit #; y-axis is DQS delay (1~15)
    ooooo----- AC8317 preloader v66573 -----
    Init SD2 Card
    Send CMD0
    Send CMD8
    Send CMD8 unkown
    Send ACMD41
    SD Card Ready
    Send CMD2
    Send CMD3
    eboot_img_des:
    Support SSC
    delay tap= 3 DLINE=2 , count=13 @ confidence=16
    A1 PLL calibration done! Final delay is 3
    delay tap= 2 DLINE=2 , count= 4 @ confidence=16
    CTL PLL calibration done!Final delay is 2
    0 3 6
    1 3 6
    2 3 0
    3 3 0
    MIOCK jitter meter
    best DQS0 fine tune = 2
    best DQS2 fine tune = 26
    best DQS3 fine tune = 25
    xxxxxxxoxxxoxoooxxxxxxxooxooxooo
    ooooxoooooooxoxxooooooxooooooooo
    ooooxxoxooxxxxxxooooooxooooooooo
    ooxxxxxxxxxxxxxxooooooxoooooooxo
    xxxxxxxxxxxxxxxxoxoooxxxoooxxxxo
    xxxxxxxxxxxxxxxxoxoxxxxxxxxxxxxx
    error on bit 22 ,setup_time =hold_time =0!!
    RX DQ/DQS calibration fail!
    DATLAT calibration
    DATLAT Default value = 0xc
    TAP= 8, err_value=0xffffffff, begin=0, first=255, sum=0
    TAP= 9, err_value=0xffffffff, begin=0, first=255, sum=0
    TAP=10, err_value=0xffffffff, begin=0, first=255, sum=0
    TAP=11, err_value=0x 400000, begin=0, first=255, sum=0
    TAP=12, err_value=0x 400000, begin=0, first=255, sum=0
    TAP=13, err_value=0x 400000, begin=0, first=255, sum=0
    TAP=14, err_value=0x 400000, begin=0, first=255, sum=0
    TAP=15, err_value=0x 400000, begin=0, first=255, sum=0
    no DATLAT taps pass
    Preloader Reboot is working now.
И так бесконечно...Что может быть?
фото магнитолы
фото платы андроид
фото платы
Goulbak
Сообщение #2 от 21/03/2021 16:56 цитата
[Привет,
У меня такой же аппарат и такая же проблема! Вы нашли решение ?
