AEG-ELECTROLUX LAVAMAT L16830
На страницу Пред.  1, 2
ALBABEN
ALBABEN
Сообщение #21 от 05/06/2016 13:30 цитата
Kaskad11 писал:
ALBABEN, if the module works, check the periphery. There are no miracles.
But I see miracles. Electronic plaques, resistance, pressostat, sesnor temperature are tested and working another perfect washing. and also the drying resistance (maybe it gives leak) but everything is ok.
- It happened and wonders. I have to pick a priest or a preacher to read and to sing смех смех
Сообщение #22 от 05/06/2016 13:44 цитата
ALBABEN, "Мне нужно выбрать священника или проповедника читать и петь" -
You will not fill "fault"...
ALBABEN
ALBABEN
Сообщение #23 от 05/06/2016 15:01 цитата
not issue any error or service when we test the shove. it seems like everything goes well. but we test gives the temperature interval relay. giving intervals, give without loving valve so that water and slowly filled with water. If one error then exhale valve remains open and is filled with water. to the washing machine but not making any problem.
- I tried the moment that gives water to heat relay, relay I've met, but show off the relay if the temperature error has left the meeting.
- Really the case with surprising why not happened ever. not know how to explain the basis of logic, there is no excuse.
