yardie
Condenser dryer regularly maintained and cleaned, used indoors only with adequate ventilation surrounding the machine.
After a dry cycle returned to find No Power or response from control panel.
Control Board:
Mark016R
P/N: 2963281900
R4 - 39ohm resistor(open, burnt out), D2 - 1N4007 (suspected faulty) and C1 - 0.1uF safety film cap(low capacitance) replaced.
U1 - LNK364PN shorted between drain and source so replaced which was probably the cause of the resistor burning out.
Still no power/signs of life!
Decided to replace other caps and diodes anyway but still No life!
So D1,9,11,12,13,14 1N4007 replaced with UF4007's.
Cap's C3,4,11,13,18,14 and 24 replaced.
Not yet replaced D7 or D8 as not found suitable replacements - BYV26C.
240V getting to the board and 78M05 giving 5v output from 14v produced by the LNK364PN.
Suspect faulty Atmega16L but not sure where to go now!
Please help, thankyou.
IMG_20181231_15889.jpg 85 КБ Скачано: 217 раз(а)
IMG_20181231_40956.jpg 90.66 КБ Скачано: 212 раз(а)
IMG_20181231_5561.jpg 61.96 КБ Скачано: 183 раз(а)
mileshca
yardie
Thanks, LNK364PN does produce 14v dc for 5v reg which outputs 5v so that part appears to be working.
I believe the xfrm sec will only be active when relay RL3 is activated which will be when a programme is running as it will also start the drum motor on RL2 i.e after the programme dial is set and the start button is pressed.
So the problem lies before the xfrm is made active unless I am missing something. |
eskander
yardie
Good lady of the house, she work me like a horse! |
тю
это что форум уже не русскии !? |
Jampers
тю писал: | это что форум уже не русскии !? |
а что не шаришь по буржуйски ??
Руссковопрошающего сразу же загнобили бы. Masters of to inspire not tried? Не так ли?
А тут проявили терпимость, так сказать русское гостеприимство. |
Kaskad11
Jampers, а при чём здесь "русское гостеприимство"? Правилами не запрещено, хоть на китайском. Хотя я где то вроде читал, может не на этом форуме, что разрешено по русски и по английски. Так что в любом случае всё по феншую. |
9. Писать сообщения разрешается только на русском или английском языках. В первом случае в качестве набора знаков должна использоваться кириллица, во втором - латиница. |
