T-con X3853TPZ Used in Many LCD's
imran khan
13/12/2014 02:17
SHARP LC-46RS46, LC-32D640,
LC-32D64U, LC-46B54U,
LCD 64A63 and
SONY KDL-55NX720 use this Timing control (T-con) X3853TPZ on this t-con i have found short circuit SMD mark KW (N - F.E.T) replace with 2N7000,Now i need schematic of above t-con board,
Please help me.
imran khan
13/12/2014 19:05
When i uploads the error shows
Приложение должно иметь меньше чем 1200 пикселей в ширину и 1200 пикселей в высоту
Извините, вы достигли максимального ограничения квоты закачек: 10 МБ
alexander3311
13/12/2014 20:51
Уменьшай размер фото.
imran khan
14/12/2014 06:05
Could not ....this action also fails when i want to up load Zip or pdf files.
ДОБАВЛЕНО 14/12/2014 03:13
I found short circuit s.m.d mark KW and data books shows N-channel mofet,schematic of t-con board help me a lot to compare correct voltages.
