AleksandrM
А можешь кодами поделиться? |
Alexzz
AleksandrM
Интересуют все, или это слишком...? |
Alexzz
Ну тогда переводить каждый не буду.
Вот список:
F01: Triac Short circuit
Overhaul CNE
Replace Card
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
F03: Open/Short-Circuited NTC Found
Overhaul CNA
Control NTC Wiring
Control CNA/NTC Wiring Continuity
Replace NTC
Replace Card
F04: Overflow and Pressure Switch Empty found at the same time (Pressure Switch stuck on Empty)
Overhaul CN1
Overhaul Pressure Switch Contacts
Control CN1/Pressure Switch Continuity
Replace Pressure Switch
Replace Card
F05: Blocked Pump or Pressure Switch stuck on Empty Found
Overhaul CNF (pump connector)
Overhaul Pump Connector
Control Pump Filter
Control Pump Windings
Change Pump
Replace Card
F06: Selector Error (a part no. cannot be found)
Overhaul CND (selector connector)
Overhaul Selector Connector
Control Selector/CND Continuity
Control Selector Motor
Replace Selector
Replace Card
F07: Resistance Relay Stuck
Overhaul CN1
Overhaul CN1
Overhaul Resistance Connection
Replace Card
Replace Card
F08: Resistance Missing or Pressure Switch stuck on Full Found
Overhaul CN1
Overhaul Pressure Switch Connection
Replace Resistance
Replace Card
F09: Machine Setup Error Found
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
F10: Pressure Switch Empty and Full or neither Empty nor Full Pressure Switch Found
Overhaul CN1
Overhaul Pressure Switch Wiring
Replace Card
F11: Pump Feedback Missing
Overhaul CN1
Overhaul CNF
Overhaul Pressure Switch Connector
Replace Pump
Replace Card
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
F14: Dryer connector open or not connected
1. Check the efficiency of the terminals on the CNI connector board
2. Overhaul CN1
3. Overhaul connector connection
4. Replace the board.Merloni Elettrodomestici
F15: Dryer connector is always active
2. Overhaul connector connection
3. Overhaul the pressure sensor connection
4. Replace the connector
5. Replace pressure sensor
6. Replace the board
F16: Non-functioning basket block
1. Go over connector card CNC
2. Go over connector basket block
3. Control Continuity of cabling CNC / basket block and basket block supply
4. Replace basket block
5. Replace card |
AleksandrM
Спасибо огромное!!! |
Волод
Спасибо ВСЕМ за советы, осталось проверить версию AIexzz.,больше вариантов не осталось.
Код ошибки на Аристон AL149XEX,за один круг ком.аппар. лампочка моргает одной вспышкой 4раза .
Eсли дело в прошивке, то помогите прошивкой,версия процессора 1.32
e-mail:iserv@arat.ru |
Alexzz
Подсчёт морганий не за круг а между паузами, большими чем 2 сек. Я думаю, что в этом случае код будет 1, то есть пробит симистор двигателя. Но из своего опыта знаю, что этот код возникает ещё и в случае пробоя на массу обмоток двигателя. Прозвоните движок мегером на массу. Именно мегером, чтобы было пробойное напряжение, тестер со своими 9 вольтами может и не показать. Бывает, что причина в элементарной утечке, когда вода попадает на мотор. |
Андре
А если моргает три раза, потом промежуток 2 сек, потом три раза и т.д. то это ошибка F03? Но я проверил термосопротивление (около 20 кОм), терморегулятор, все цепи,вроде все ОК, что еще можно сделать. Машинка Indesit W84tx ex. |
Alexzz
Это больше похоже на несоответствие прошивки EEPROM. Если поставить в старую большую плату прошивку от новой, маленькой, то так будет точно, проверено. Возможно, и наоборот, тоже такое может случиться. |
Mak
to vsem: считаем заново
to Alexzz: странно знаешь коды, а как считать не расказал.
Ошибка F03 должнa выглядеть так:
1 Вспышка (или 2-3 очень коротких вспышки - зависит от прошивки)
пауза 2-3с
1 Вспышка (или 2-3 очень коротких вспышки)
пауза 2-3с
пауза 8-9 с и далее по новой. Отсчет кода надо вести между паузами 8-9 секунд. |
Alexzz
Тут просто ошибка, которой видимо нет в списке кодов, или она выдаётся неверно. Это просто из личного опыта. Был прецедент, когда я ошибочно прошил прошивку от другой версии платы, и результат был именно таким. Сразу после включения, независимо ни от чего, через секунд 5 машинка вставала на ошибку, и выдавала 3 сплощных моргания с интервалом в 1 секунду и потом пауза около 2х секунд.
Обычно когда выдаётся ошибка из списка, то каждая единица моргания происходит серией мелких вспышек около секунды и около секунды пауза. Начало и конец отсчёта определяет длинная пауза более 5 секунд. Да в документации указан интервал 8-9 секунд, но не будешь же с секундомером стоять.... |
rprman
Alexzz, а как будет моргать, например, F13? |
Alexzz
DImon974
Саша если у тебя W43 t !!! то не какие коды тебе не помогут. У тебя механический командоаппарат. У этих стиралок нет теста устройств машины. Alexzz внимательней читай модель. |
Alexzz
DImon974, он не указал модель полностью, поэтому я даже и не смотрел. Там как минимум с десяток моделей начинаются на W43. А раз человек спрашивает код, значит я ему верю. |
DImon974
Ну извини если что не так |
DImon974
А по русски коды ошибок нужны? |
Юрий Бабарыкин
Будь добр, скинь, а то у меня мерлоневские диски накрылись. |
DImon974
DImon974
