TV RECOR RC4021 A-A Поиск каналов не работает (РЕШЕНО) | |||||
| cackokonopiski 13/12/2008 22:45 |
Поиск каналов не работает. При поиске каналов он не остановить.
Я заменила все кондезатор в SMPS, HOR, MF. Имеет некоторое представление о том, что может быть. Я надеюсь, вы меня понимаете ![]() |
| мастер-ломастер 13/12/2008 23:32 |
cackokonopiski, А правила , быстренько исправляемся ![]() |
| Morlock 14/12/2008 00:36 |
не совсем! |
| cackokonopiski 14/12/2008 06:30 |
May be is forbidden to write on English, is not fer, i know Sorry but I have no chooise, if I want you to undestand me. TV had has fault in SMPS modul, when I fix then had has fault in Horizontal, when I fix and that then faul in Tunning Control When try to tunning channels hi dosn't stop when hi find a channel. I replase all of Condenzators in SMPS, HOR... , MF moduls Enything else i can't remember maybe someone can help me, and have some good idea??? And sorry because I write on English, in former tekst I use a Google Translate service but maybe has some errors in teks and you can't understand me. Salute |
| АВАС 14/12/2008 16:00 |
cackokonopiski, signal IDENT a channel > CPU - search - шерше! ( deviation coil RFdet,AFC) |
| cackokonopiski 14/12/2008 16:34 |
Кто состоит в том, что катушка Вот схема! Who is that coil? Here is scheme! |
| B.B. 14/12/2008 16:54 |
cackokonopiski, TDA8305A -- 22pin -->CPU Ident 30 pin
TDA8305A - 20,21 pin --> T203 |
| АВАС 14/12/2008 17:10 |
Confirm - ident chennel 29pin CPU |
| MASTER+ 14/12/2008 18:47 |
pin10 - ёмкость АРУ. |
| АВАС 14/12/2008 19:03 |
cackokonopiski, check Q206 |
| cackokonopiski 14/12/2008 23:04 |
It's finish - done
Problem : MFT 203 Thanks for help Спасибо за помощь |
