Sony KV-HR29M91 | |||||||||
| ashraf 30/05/2010 02:13 |
Sony KV-HR29M91 Chassis AX-1
How can I recover this problem in a TV Sony KV-HR29M91 Note: I changed the FBT and the problem still exists What causes this problem and how can I solve this? |
| B.B. 30/05/2010 05:21 |
ashraf, Interest is framed in violation pravil. ----> http://monitor.espec.ws/section1/topic133974.html
P.S. Add firmware with this chassis |
| ashraf 30/05/2010 16:10 |
Были отправлены firmware и ничего нового |
| Alexasha 30/05/2010 16:58 |
You must look for a faulty electrolytic capacitor |
| ashraf 30/05/2010 19:12 |
Survey efforts are described and found Onhamtabqp picture |
| Alexasha 30/05/2010 19:45 |
Perhaps in supply circuits, need search or replace all |
| goga_tv 30/05/2010 23:09 |
ashraf, I'm not sure that is defective block which you have shown in the figure. Find out what makes this effect. Block video, or horizontal scan. |
| Telik 30/05/2010 23:50 |
The defect was to replace FBT, or after? What voltage gives the power supply?
By defect recalls dead electrolyte in the power supply C8011, C8012-1500mkf\250v, or C6512-33mkf\160v. |
| B.B. 31/05/2010 06:17 |
ashraf, We need the firmware of the chassis and the photo board. Please publish it here in its theme. Thank you. |
| ashraf 31/05/2010 14:37 |
Изменены все конденсаторы
KV-HR29M91_HR34M91 Ch.AX-1 schematic |
| Alexasha 31/05/2010 20:45 |
If you work without measurements - replacement driver |
| ashraf 02/06/2010 01:12 |
Поиск driver Большое спасибо |
