Power on problem (chassis:3P66)
alamgir80
24/07/2012 20:17
chassis:3P66
UOC- TDA12156PS/N3/3/AK8
all voltage become 0 in 1 sec but when short Q605 collector & emitor 3.3v, 5.1v B+ standby 55v are ok. try to change uoc, eht, hot and w6553 related component but still no luck . please help me.
LordLostr
24/07/2012 20:28
alamgir80,А по Русски? Чё хочешь?
киев
24/07/2012 20:37
LordLostr, имеет полное право подмигивание
Правила конференции писал:
9. Писать сообщения разрешается только на русском или английском языках. В первом случае в качестве набора знаков должна использоваться кириллица, во втором - латиница.
aze1959
24/07/2012 20:40
alamgir80, check IC602 and D601. On the Q605 base submit 0 volts.
alamgir80
24/07/2012 21:09
Changed ic602 and Q601 nothing new. when put 0 in Q605 all volt(110v,46v,12v,12v) come for 1sec.
aze1959
24/07/2012 21:15
alamgir80, darings of L602 also include. What does that change? IC601 4 pin how many tension? C607?
alamgir80
24/07/2012 21:55
After change L602, C607 same problem. and change all components related ic601.
aze1959
24/07/2012 22:13
alamgir80, take your time. Announce a food IC601 4 pin. there should be about 12-18 volts and change breakthroughs. If there is no that or IC601 is faulty or C609 or R602 or R603
alamgir80
24/07/2012 22:49
IC601 change 3 times and components change as you say, still same.
aze1959
24/07/2012 22:54
alamgir80, IC601 structurally generator and power key. A generator food via R602 and R603 resistors. 4th pin of IC601. How many volt?
alamgir80
25/07/2012 13:52
@ aze1959
Many many thanks to you for help. my problem solve after change R621 220k. улыбка
мастер-ломастер
25/07/2012 13:59
alamgir80, эта проблема известна ещё с МП-3-3, когда подстроечник "гулял" или последовательно с ним резистор--2ком.
aze1959
25/07/2012 14:28
alamgir80, one of standard defects
alamgir80
25/07/2012 20:49
One big problem from "Chassis:3P66" reading firmware with ponyprog and IC-Prog. After write firmware with "ponyprog" and "IC-Prog" cannot strart TV.
aze1959
25/07/2012 21:15
alamgir80 писал:
with this problem it is better to you to address to the person under a nickname of "key-s" to send it the personal message or to write on mail
valya
26/07/2012 05:37
С удовольствием почитал гы-гы ..... чё , пайка отвалилась ? гы-гы ..... или , таки , шо ?
mileshca
26/07/2012 07:57
valya, ну так обматерили бы я не заметил голливудская улыбка
Yuritsh
26/07/2012 11:33
Ну вы ребята даёте. Тут же почти все слова как русские. Вот только в слове start он сделал ошибку.
aze1959 писал:
alamgir80 писал:
Возможно у него просто локалка заблокирована. Надо попробовать включить с пульта.
aze1959
26/07/2012 14:14
может быть и так
на этом слове я тоже "спотыкнулся" и несколько неверно понял смысл написанного
alamgir80
26/07/2012 20:51
After write with external eeprom copier no any problem.
But when write with ponyprog and ic-prog no result!
It,s ponyprog and ic-progsoftware bug? or
(chassis: 3P66) security ?
aze1959
26/07/2012 21:00
alamgir80 писал:
Put the true that is not written down memory wait while the processor identifies it and will register and then come into service installations and manually establish. service I attach
alamgir80
26/07/2012 21:07
can start (chassis: 3P66) with blank memory ?
aze1959
26/07/2012 21:50
alamgir80 писал:
yes
