Автор | Сообщение |
ДядяЮра
В наличии:
MI12864PO 24 pin SSD1303T10
TD024THEB2 304000012
BL-PSD231-131A FPC-PSD231-131A
BL-T27P05V0
LTP280QV-E01 +Touch SS-A19C C07 LTP280QV-REV1.3
PT035TN01 V.6 +Touch 070365
LQ035Q1DG01+Touch 320x240 QPWBM0613TPZZ
TD035SHEB4 2000000052
KD35G3-320240-A1+Touch A035-9D
AT043TN13 +Touch 1402-390 LTTI 32000257-22
AT043TN24 V.1+Touch BB241G 315B 32000576-00
AT043TN24 V.1 LCD 32000576-00
AT043TN24 V.4+Touch 33SQU/20000527-13 20000494-04
BLC430-16C LCD HW48027F-0L-0A-30
BLC430-23A/ZBH043GT-11+Touch ST0009 ZBH043GT-11
FTG430D36Z-F-00+Touch UT343-043 FTG430D06Z-00
CPT430-8B+Touch T1413A-E3 FPC4304006
CPT430-8B+Touch T1642A-A5 FPC4304006
LQ043T1DG04+Touch BA295B QPWBM0787TPZZ
HSD043GT09-TI (QZ.T.301-430-71D) LCD 721Q310B63-A2
WX4300B-M03 85LS+Touch AF1289 WX4300F-M04#03
H-H043L-07A+Touch BA241G 315B 721Q310B63-A2
H-B043L-08B+Touch BB241G 315B FPC H-B043L-08B V02
HLY430ML504-07A+Touch JK24089D2/043089 721Q310B63-A2
KR043PB3S LCD 00162-A
KD43G16-40NС-A15 +Touch
59.05A4.005/A050FW01+Touch TR4-050F-09 02 54.20019.058
59.05A4.005/A050FW01 LCD 54.20019.058
AT050 LCD 8T000291-00
AT050TN / OZL.729-050-12K +Touch 051005 8T000291-00
AT050TN / OZL.729-050-12K LCD 32000579-02
AT050TN / OZL.729-050-12K LCD 8T000291-00
AT050TN33 V.1 LCD 8T000291-00
HL050TN30-BDL+Touch 051010 8T000291-00
HLY050ML115-12A+Touch 050038 721Q310046-A0
HLY050ML115-12A+Touch 051024 721Q310046-A0
HLY050ML115-12A+Touch 051024 721H410014-A0
HLY050ML115-12A+Touch STR0020 714H410014-A0
HLY050ML115-12A+Touch ST0008 714H410129-A0
H-A050L-12P + Touch BA230E 54.20014.081
H-H050L-12K + Touch T1589A-B2 721H410114-A0
H-H050L-12L + Touch EK52M.595 HSD050IDW1-A20-RIC
H-Q050L-12D + Touch BB242 278D 32000579-02
HD050W0064A/FTG500D09Z-00 + Touch FTG500D01Z-01
KD50G10-40NC-A3 LCD KD50G10-40NC-A3
KD50G23-40NB-A1 LCD KD50G23-40NB-A1-REVC
KD50G23-40NB-A16 LCD KD50G23-40NB-A1-REVC
ZBH010GT-01/SP50-03C/ZBH050GT-01+Touch ST0008 ZHB010GT-01
AX5.0-G2 + Touch ZK1006 AX5.0-G2
060RFZ03 FP-9 + Touch VTW4061A4 060RFZ03 FP-9
KD060G1-40NC-A5 + Touch BB298C KD060G1-40NC-A1
KD060G1-40NC-A1 LCD KD060G1-40NC-A1
AT070TN90 V.1 20000938-00
AR070D08N15 +TouchCZY154-B AR070D08N-FPC-V1
BOE7.0 60 PIN 36LED
BOE 070 REV0 20810700150196 KR070PC5S
BOE 070 REV1 20810700160028-01+Touch HN-P070-75 A08
AL0203B 1024х600 30 pin C700H30-I1
CLAA070MA0ACW 800x600
CRD070TN01-40M02 40 pin 1024x600 105х165х3,5 32001358-00 3175
CMC070IDW6-A20 + touch A1712H3SJJ622 800x480 721Q360D44-A0/721H410A44-A0
CPT 070 REV.0 20810700180 119 LCD 800x600 7300100058 E203460
CPT070LF02N-A12/SS H-CPT070LF02N-A12 800x480 7300100070
FB-D058-05/7D-LED18/AT070TN90 V.1+Touch BB0635A 20000938-00
FTG700D13W-F-01 + touch B1712H3SKC493 FPC-FTG700D03Z-00
FGD700F5002A+ touch AS71-163097D1-SMJ 50pin 65мм FPC7005002/E231732 800 x 480
FGD700F5002A LCD 50pin 65мм FPC7005002/20100520 800 x 480
FY7018Q01HD-2.8-A08 40 pin 1024x600 105х165х3,5 32001358-00
FY700H04-K-A05 FB-D064-07 + touch LM70SC53 721Q360D44-A0
FY700Q03-B-A06/ZM70062R 3mm 20000938-00 FPC 800 x 480
HB070-DM454-15C+touch AV70-160093A1-SMJ 20000938-00
H-B07015FPC-20 800x480 H-B07015FPC-20
H-B070D-18CE H-B07012FPC-72
H-B070D-18FB 1024x600 60 pin 164.9*103.8*3.5 H-B07018FPC0-C00
H-B070D-24K H-B07015FPC-30
H-H070D-21A 800x480 721H410A44-A0
HL070TN93 C25-PU-DPX-A + Touch AO70-159094A1-SMJ 20000938-00 FPC
HL070TN93 C25-PU-DPX-A 800x480 50pin шл 45мм 20000938-00 FPC
HLY070ML209-21A + Touch BA360A 50pin 20000938-00 FPC
HLY070ML290-21A 50pin 7214H10C44-A0
HLY070ML293-15A 50pin TM070RFH14/1540014432
HLY070ML293-15A + Touch AS71-163097D1-SMJ FPC582 BF268-070-01P5 TM070RFH14
HSD070ISN1 REV 1-D00-C11 LCD 7214H60062-A1
HSD070A23-3WFL 7214H10C44-A0
HV070WS1-101 1024x600 30pin
KW-AT070TN93 тонк 3mm 20000938-00
KW-AT070TN93-15LED 3.5mm 20000938-00 FPC
RS3-WVN70034A 800x480 FPC3-WV70021AV0
SL007DH18B16 40 pin 1024x600 102х164х3,5 SL007DH05FPC/XZH 20120725 3175
SL007DH24B08 40 pin 1024x600 102х164х3,5 SL007DH26FPC-V2
LJJ 70018-01/V1-07013018A 20000938-30/
WY070ML188IN12A 7DD1+ FPC
LD070WS2-SL03/SL04/SL06 1024x600 px. 30 pin
TD080WX827-V3 3D 1280х768 TM080XPH01/1547000100
LC080DG35 V01 20001086-10 Ver.C/32-D043805 Ver.C
GL080001T0-50/SP800-01D LCD GL080001T0-50
FSL080.024.1059-7A0 +Touch DLW-0636 (HB080-DM805-1) FPC_T2FPC_T1/1540009311
TKR473-080-18A LCD FPC_T2FPC_T1/1540009312
LS080HT111/ME80AJC 800x600 418000019903
HB080-DM854-30C 7300100083/E242868
H-B080D-24G H-B08018FPC-40
H-B080D-270 H-B08027FPC-E0
TL081WXV03 V5 1280x800 FPC081-03P40-A4/KTD081C04-05
LTL089CL02-001 1920×1200 IPS LTL089CL02-001
ED090NA-01D 1280x800 32001103-01
SL009DF18B01BL/AT090TN10 50pin 800x480 20000938-30
LP097XL02-SLQA 9"7 1024x768
HSD100IFW1 Rev 1-C00
HSD100IFW4 Rev 0-A00 |
ДядяЮра
eduard74291
Здравствуйте.
Интересует матрица V400HJ6-PE1 REv.C3
телек BBK 40LEX7158 и вторая, ST3151A07
телевизор TDL LE32F2s |
ДядяЮра
blkm/
Нужен для видеорегистратора BL-T27P05V0 |
ДядяЮра
blkm/, Форум полное говнище.
Не позволяет редактировал первую страницу.
Матриц на регистраторы уже года3 как нет. |
MustafaTamer18
bars190 писал: | Добрый день, нужна матрица + тачскрин. на матрице сзади штрих код VM04B1WD04141106073
AGL Made in Taiwan
Тачскрин TSA0342.C
Шлейф FPC-T430MTWH-16-V01 |
+1 |
ДядяЮра
MustafaTamer18, с огу уточнить только после 10 числа. |
ДядяЮра
MustafaTamer18, Таких дисплеев уже нет и не будет. |
mirwlad
Добрый день. Нужна матрица samsung ue40mu6100u CY-GK040HGLV4V, пульт Smart с доставкой в Минск |
