ПРОДАМ Программатор EZP2010 (USB, высокоскоростной) | |||||
| dect 27/07/2012 16:36 |
Продам высокоскоростные USB программаторы
EZP2010 комплектация 1. Программатор - 1шт 2. Диск с ПО - 1 шт 3. Кабель USB - 1шт 4. Блок питания для автономной работы - 1 шт 5. Переходнички для SMD EEPROM (не ZIF) - 2 шт цена 400грн оплата на карту Приватбанка, Укрсоцбанка отправка транспортными перевозчиками ********************25 SPI FLASH******************************************************************* AMIC: A25L05P, A25L512, A25L010, A25L10P, A25L020, A25L20P, A25L040, A25L40P, A25L080, A25L80P, A25L016, A25L16P, A25L032 ATMEL: AT25F512, AT25F512A, AT25F512B, AT25F1024, AT25F1024A, AT25FS010, AT25DF021, AT25F2048, AT25DF041A, AT25F4096, AT25FS040, AT26F004, AT26DF081A, AT25DF161, AT26DF161, AT26DF161A, AT25DF321, AT25DF321A, AT26DF321, AT25DF641 EON: EN25F05, EN25LF05, EN25P05, EN25D10, EN25F10, EN25LF10, EN25P10, EN25D20, EN25F20, EN25LF20, EN25D40, EN25F40, EN25LF40, EN25D80, EN25F80, EN25Q80, EN25T80, EN25B16, EN25B16T, EN25D16, EN25F16, EN25Q16, EN25T16, EN25B32, EN25B32T, EN25F32, EN25P32, EN25Q32, EN25B64, EN25B64T, EN25F64, EN25P64, EN25Q64, EN25F128, EN25Q128 ES: ES25P10, ES25P20, ES25M40, ES25M40A, ES25P40, ES25M80, ES25M80A, ES25P80, ES25M16, ES25M16A, ES25P16, ES25P32 ESMT: F25L004A, F25L04UA, F25L008A, F25L08PA, F25L016A, F25L16PA, F25L32PA, F25L32QA MXIC: MX25L512, MX25V512, MX25L1005, MX25L2005, MX25L4005A, MX25V4005, MX25L8005, MX25V8005, MX25L1605D, MX25L1635D, MX25L3205D, MX25L3225D, MX25L3235D, MX25L3237D, MX25L6405D, MX25L12805D NEXFLASH: NX25P10, NX25P20, NX25P40, NX25P80, NX25P16, NX25P32 PMC: PM25LV512A, PM25LV010A, PM25LV020, PM25LV040, PM25LV080B, PM25LV016B SAIFUN: SA25F005, SA25F010, SA25F020, SA25F040, SA25F080, SA25F160, SA25F320 SPANSION: S25FL004A, S25FL008A, S25FL016A, S25FL032A, S25FL064A SST: SST25VF512, SST25VF512A, SST25VF010, SST25VF010A, SST25VF020, SST25VF020A, SST25VF040, SST25VF040A, SST25VF040B, SST25VF080B, SST25VF016B, SST25VF032B, SST25VF064C ST: M25P05A, M25P10A, M25PE10, M25P20, M25PE20, M25P40, M25PE40, M25P80, M25PE80, M25PX80, M25P16, M25PE16, M25PX16, M25P32, M25PX32, M25P64, M25PX64, M25P128 WINBOND: W25P10, W25X10, W25X10A, W25X10AL, W25X10L, W25P20, W25X20, W25X20A, W25X20AL, W25X20L, W25P40, W25X40, W25X40A, W25X40AL, W25X40L, W25P80, W25X80, W25X80A, W25X80AL, W25X80L, W25P16, W25X16, W25P32, W25X32, W25X64 ãâ€â€ ********************24 EEPROM******************************************************************* ATMEL: AT24C01, AT24C01A, AT24C01B, AT24C02, AT24C02A, AT24C02B, AT24C04, AT24C04A, AT24C04B, AT24C08, AT24C08A, AT24C08B, AT24C16, AT24C16A, AT24C16B, AT24C32, AT24C32A, AT24C32B, AT24C64, AT24C64A, AT24C64B, AT24C128, AT24C128A, AT24C128B, AT24C256, AT24C256A, AT24C256B, AT24C512, AT24C512A, AT24C512B, AT24C1024, AT24C1024A, AT24C1024B CATALYST: CAT24C01, CAT24WC01, CAT24C02, CAT24WC02, CAT24C04, CAT24WC04, CAT24C08, CAT24WC08, CAT24C16, CAT24WC16, CAT24C32, CAT24WC32, CAT24C64, CAT24WC64, CAT24C128, CAT24WC128, CAT24C256, CAT24WC256, CAT24C512, CAT24WC512, CAT24C1024, CAT24WC1024 COMMON: 24C00 3V, 24C00 5V, 24C01 3V, 24C01 5V, 24C02 3V, 24C02 5V, 24C04 3V, 24C04 5V, 24C08 3V, 24C08 5V, 24C16 3V, 24C16 5V, 24C32 3V, 24C32 5V, 24C64 3V, 24C64 5V, 24C128 3V, 24C128 5V, 24C256 3V, 24C256 5V, 24C512 3V, 24C512 5V, 24C1024 3V, 24C1024 5V FAIRCHILD: FM24C01L, FM24C02L, FM24C03L, FM24C04L, FM24C05L, FM24C08L, FM24C09L, FM24C16L, FM24C17L, FM24C32L, FM24C64L, FM24C128L, FM24C256L, FM24C512L, FM24C1024L * HOLTEK: HT24C01, HT24LC01, HT24C02, HT24LC02, HT24C04, HT24LC04, HT24C08, HT24LC08, HT24C16, HT24LC16, HT24C32, HT24LC32, HT24C64, HT24LC64, HT24C128, HT24LC128, HT24C256, HT24LC256, HT24C512, HT24C1024 * ISSI: IS24C01, IS24C02, IS24C04, IS24C08, IS24C16, IS24C32, IS24C64, IS24C128, IS24C256, IS24C512, IS24C1024 * MICROCHIP: 24AA00, 24C00, 24LC00, 24AA01, 24AA014, 24C01C, 24LC014, 24LC01B, 24AA02, 24LC02B, 24AA024, 24AA025, 24AA04, 24C02C, 24LC024, 24LC025, 24LC04B, 24AA08, 24LC08B, 24AA16, 24LC16B, 24AA32, 24LC32, 24AA64, 24FC64, 24LC64, 24AA128, 24FC128, 24LC128, 24AA256, 24FC256, 24LC256, 24AA512, 24FC512, 24LC512, 24AA1024 * NSC: NSC24C02, NSC24C02L, NSC24C64 * RAMTRON: FM24C04A, FM24CL04, FM24C16A, FM24CL16, FM24C64, FM24CL64, FM24C256, FM24CL256, FM24C512 * ROHM: BR24C01, BR24L01, BR24C02, BR24L02, BR24C04, BR24L04, BR24C08, BR24L08, BR24C16, BR24L16, BR24C32, BR24L32, BR24C64, BR24L64 * ST: ST24C01, ST24C02, ST24C04, ST24C08, ST24C16, ST24C32, ST24C64 * XICOR: X24C01, X24C02, X24C04, X24C08, X24C16 * ãâ€â€ * ********************93 EEPROM******************************************************************* * AKM: AK93C45AV, AK93C55AV, AK93C65AV, AK93C75AV * ATC: ATC93C46, ATC93LC46(16bit), ATC93LC46(16bit)-SOP8, ATC93LC46(8bit), ATC93LC46(8bit)-SOP8, ATC93C56, ATC93LC56(16bit), ATC93LC56(16bit)-SOP8, ATC93LC56(8bit), ATC93LC56(8bit)-SOP8, ATC93C66, ATC93LC66(16bit), ATC93LC66(16bit)-SOP8, ATC93LC66(8bit), ATC93LC66(8bit)-SOP8 * ATMEL: AT93C46(16bit), AT93C46(16bit)-SOP8, AT93C46(8bit), AT93C46(8bit)-SOP8, AT93C46A, AT93C56(16bit), AT93C56(16bit)-SOP8, AT93C56(8bit), AT93C56(8bit)-SOP8, AT93C57(16bit), AT93C57(16bit)-SOP8, AT93C57(8bit), AT93C57(8bit)-SOP8, AT93C66(16bit), AT93C66(16bit)-SOP8, AT93C66(8bit), AT93C66(8bit)-SOP8, AT93C86(16bit), AT93C86(16bit)-SOP8, AT93C86(8bit), AT93C86(8bit)-SOP8 * CATALYST: CAT93C46(16bit), CAT93C46(8bit), CAT93C46A, CAT93C46I, CAT93C56(16bit), CAT93C56(8bit), CAT93C56A, CAT93C57(16bit), CAT93C57(16bit)-SOP8, CAT93C66(16bit), CAT93C66(8bit), CAT93C66A, CAT93C86(16bit), CAT93C86(8bit) * COMMON: 93C46(16bit), 93C46(8bit), 93C56(16bit), 93C56(8bit), 93C66(16bit), 93C66(8bit), 93C86(16bit), 93C86(8bit) * EXEL: XL93C06, XL93C46, XL93CS46, XL93LC46, XL93C56, XL93LC56, XL93C66, XL93LC66 * FAIRCHILD: FM93C06AM8(16bit), FM93C06AM8(8bit), FM93C06M8, FM93C06N, FM93C46AM8(16bit), FM93C46AM8(8bit), FM93C46AN(16bit), FM93C46AN(8bit), FM93CS46(16bit), FM93C56AN(16bit), FM93C56AN(8bit), FM93CS56(16bit), FM93C66AM8(16bit), FM93C66AM8(8bit), FM93C66AN(16bit), FM93C66AN(8bit), FM93C66B, FM93C66M8(16bit), FM93C66MT8(16bit), FM93C66N(16bit), FM93CS66(16bit), FM93C86AM8(16bit), FM93C86AM8(8bit), FM93C86AN(16bit), FM93C86AN(8bit) * HOLTEK: HT93LC46A(16bit), HT93LC46A(8bit), HT93LC56A(16bit), HT93LC56A(8bit), HT93LC66A(16bit), HT93LC66A(8bit) * ICT: ICT93C46(16bit), ICT93C46(8bit), ICT93C56(16bit), ICT93C56(8bit), ICT93C66(16bit), ICT93C66(8bit) * ISSI: IS93C46(16bit), IS93C56(16bit), IS93C66(16bit) * MICROCHIP: 93C06(16bit), 93C06(16bit)-SOP8, 93AA46(16bit), 93AA46(8bit), 93AA46(8bit)-SOP8, 93C46(16bit), 93C46(16bit)-SOP8, 93C46A, 93C46B, 93LC46(16bit), 93LC46(16bit)-SOP8, 93LC46(8bit), 93LC46(8bit)-SOP8, 93LC46A, 93LC46B, 93LC46B-SOP8, 93AA56(16bit), 93AA56(8bit), 93AA56(8bit)-SOP8, 93C56(16bit), 93C56(16bit)-SOP8, 93C56(8bit), 93C56(8bit)-SOP8, 93C56A, 93C56A-SOP8, 93C56B, 93C56B-SOP8, 93LC56(16bit), 93LC56(16bit)-SOP8, 93LC56(8bit), 93LC56(8bit)-SOP8, 93LC56A, 93LC56B, 93LC56B-SOP8, 93AA66(16bit), 93AA66(8bit), 93AA66(8bit)-SOP8, 93C66(16bit), 93C66(16bit)-SOP8, 93C66(8bit), 93C66(8bit)-SOP8, 93C66A, 93C66A-SOP8, 93C66B, 93C66B-SOP8, 93LC66(16bit), 93LC66(16bit)-SOP8, 93LC66(8bit), 93LC66(8bit)-SOP8, 93LC66A, 93LC66B, 93LC66B-SOP8, 93AA76(16bit), 93AA76(8bit), 93C76(16bit), 93C76(8bit), 93LC76(16bit), 93LC76(8bit), 93LC76A, 93LC76B, 93AA86(16bit), 93AA86(8bit), 93C86(16bit), 93C86(8bit), 93LC86(16bit), 93LC86(8bit), 93LC86A, 93LC86B NSC: NSC93C06, NSC93C06-SOP8, NSC93CS06, NSC93C46, NSC93CS46, NSC93C56, NSC93CS56, NSC93S56, NSC93C66, NSC93CS66, NSC93C86 * ROHM: BR93LC46, BR93LC46RF, BR93LC56, BR93LC56RF, BR93LC66, BR93LC66RF * ST: ST93C06, M93S46, M93S46-SOP8, M93S46-T8, M93S46R, M93S46R-SOP8, M93S46W, M93S46W-SOP8, ST93C46, M93S56, M93S56-SOP8, M93S56R, M93S56R-SOP8, M93S56W, M93S56W-SOP8, ST93C56, M93S66, M93S66-SOP8, M93S66R, M93S66R-SOP8, M93S66W, M93S66W-SOP8, ST93C66 * ãâ€â€ * ********************25 EEPROM******************************************************************* * ATMEL: AT25010, AT25020, AT25040, AT25080, AT25160, AT25320, AT25640, AT25128, AT25256, AT25512 * CATALYST: CAT25C01, CAT25C01P, CAT25C01S, CAT25C01U, CAT25C02P, CAT25C02S, CAT25C02U, CAT25C03P, CAT25C03S, CAT25C03U, CAT25C04P, CAT25C04S, CAT25C04U, CAT25C05P, CAT25C05S, CAT25C05U, CAT25C08P, CAT25C08S, CAT25C08U, CAT25C09P, CAT25C09S, CAT25C09U, CAT25C16P, CAT25C16S, CAT25C16U, CAT25C17P, CAT25C17S, CAT25C17U, CAT25C32P, CAT25C32S, CAT25C33P, CAT25C33S, CAT25C64P, CAT25C64S, CAT25C65P, CAT25C65S, CAT25C128P, CAT25C128S, CAT25C256P, CAT25C256S * COMMON: 25010, 25020, 25040, 25080, 25160, 25320, 25640, 25128, 25256, 25512 * MICROCHIP: 25AA040, 25C040, 25LC040, 25AA080, 25C080, 25LC080, 25AA160, 25C160, 25LC160, 25AA320, 25C320, 25LC320, 25AA640, 25C640, 25LC640 * RAMTRON: FM25C160, FM25640, FM25CL64 * ST: ST25C01, ST25W01, ST25C02, ST25W02, ST25C04, ST25W04, ST25C08, ST25W08, ST25C16, ST25W16 * TI: TI2532, TI2532A, TI2564 * XICOR: XC25010, XC25020, XC25040, XC25080, XC25160, XC25320, XC25640, XC25128, XC25256, XC25512 |
| Alexasha 27/07/2012 16:49 |
20 баксов сверху, как с куста.... |
| dect 27/07/2012 17:50 |
или так http://www.ebay.com/itm/EZP2010-High-Speed-24-25-93-FLASH-USB-SPI-Programmer-/300542965048?pt=LH_DefaultDomain_0&hash=item45f9c1b538 6 баксов как с куста... а ещё они говорят в Китае по 10 баксов в рознице... Будешь удивлен, но покупая что либо и где либо на тебе зарабатывают. И по чем продавать - указывать мне не нужно. |
| dect 02/08/2012 13:03 |
есть в наличии |
| Suflion 02/08/2012 20:48 |
Интересует:
1 .Если завтра переведу Вам в обед деньги, когда Вы сможете мне его отправить ? 2. Есть ли у Вас возможность укомлектовать его подобным образом http://www.willem-ua.com/shop/107/desc/programmator-ezp2010-high-speed-spi-flash-usb-full адаптерами соответствующего качества, и сколько это будет стоить ? |
| dect 02/08/2012 21:09 |
адаптеры есть тоже, сумму, реквизиты оплаты скинул в личку |
| dect 06/08/2012 21:11 |
продаю ![]() |
| dect 09/08/2012 16:40 |
в продаже |
| dect 23/08/2012 20:33 |
ещё есть в наличии - покупаем |
| dect 31/08/2012 09:06 |
приехала новая партия программаторов... |
| dect 01/09/2012 09:01 |
Добавлен вариант продажи с адаптерами
EZP2010 Вариант 2 1. Программатор - 1шт 2. Диск с ПО - 1 шт 3. Кабель USB - 1шт 4. Блок питания для автономной работы - 1 шт 5. Переходнички для SMD EEPROM (не ZIF) - 2 шт 6. Zif Socket SOIC8 -> Dip8 150mil - 1шт 7. Zif Socket SOIC8 -> Dip8 200mil - 1шт цена 580грн |
| dect 06/09/2012 13:55 |
маленький программатор с хорошими характеристиками
ещё не все проданы - есть в наличии |
| dect 12/09/2012 14:15 |
покупаем ![]() |
| dect 17/11/2012 15:52 |
продам
есть в наличии |
| 5131251 22/11/2012 07:35 |
dect,
В беларусь переслать можно? |
| dashik65 09/01/2013 01:42 |
Сколько сейчас с адаптерами стоит?Украина,Кременчуг.Спасибо. |
| dect 09/01/2013 10:07 |
с адаптерами 550грн |
| dashik65 09/01/2013 20:09 |
Кинь реквизиты.Спасибо заранее. |
| dect 09/01/2013 21:37 |
в личке ![]() |
| МИГУЛЯ 14/01/2013 09:18 |
а мне в РОССИЮ во что обойдется? |
| dect 14/01/2013 11:25 |
57$ с доставкой |
| S-TULA 14/01/2013 21:21 |
другие есть какие прогеры ? под PIC-контролеры ...? |
| dect 14/01/2013 21:26 |
Pickit2 by sureelectronics = 32$ + доставка |
| S-TULA 14/01/2013 22:14 |
ок , спасибо почитаю про его отзывы ,понравится закажу в личку |
| sanchez.ua 19/04/2013 22:51 |
есть ли в наличии данный программатор? |
| dect 20/04/2013 22:42 |
Да, есть в наличии |
| Astah 16/06/2013 18:37 |
dect,
Здравствуйте. Во что обойдётся покупка в расширенной комплектации (с ZIF переходниками) с доставкой в Новосибирск (Россия)? Способы оплаты? Сейчас в наличии есть? |
| dect 16/06/2013 19:03 |
76$ с доставкой есть в наличии |
| Astah 16/06/2013 19:23 |
57$ с доставкой в Россию
это был вариант в "минимальной" комплектации? |
| dect 16/06/2013 19:29 |
да, вот такая EZP2010 комплектация 1. Программатор - 1шт 2. Диск с ПО - 1 шт 3. Кабель USB - 1шт 4. Блок питания для автономной работы - 1 шт 5. Переходнички для SMD EEPROM (не ZIF) - 2 шт с ZIF адаптерами 208 и 150 mil 76$ |
| kulepoff 17/05/2014 07:46 |
Программатор PROG-SL -
PIC, AVR, 24xx, 25xx, 25SPI Flash, 35xx, 45xx, 93xx, 95xx - меньше цена, больше возможностей - http://herz-nn.narod.ru/programmator-tl866sl.htm |
| dect 17/05/2014 09:08 |
Хреновая у тебя манера сунуться со своей рекламой в чужие топики!!! |
| kulepoff 17/05/2014 09:11 |
Извините... |
| dect 17/05/2014 13:38 |
не извините, а три свою рекламу нах. |
| leonid62 28/05/2014 08:18 |
708.21 руб. включая доставку! ![]() |
| dect 28/05/2014 10:04 |
Ты опоздал вставить свой пятак на 16 месяцев от даты вопроса МИГУЛИ, нужно своевременно контролировать мои темы |
| leonid62 28/05/2014 14:03 |
Для одного опоздал, для других нет! |
| Spec 30/09/2014 22:12 |
В списке этого программатора есть x24c01 я сколько не пытался - не шьет. Покупал новые микросхемы - пофиг. Может это рещается новой или старой прошивкой самого программатора - не знаю. Если кто знает - поделитесь советом. |
