ПРОДАМ запчастини до сат тюнеров | |
| valik50 22/05/2013 08:02 |
STI5518BQC $10.00
ali3329d a1 $8.50 ali3329C F1 $4.50 ali3329 B1 $8.00 ali3602 $16.00 BU808DFI $3.50 5L0380 $1.2 5m0365 $1.0 DM0265 $0.90 TM0265 $0.85 DH321 $0.70 PC817 $0.20 PCM1725 $2.5 WM8521HC $2.7 TL431 $0.19 TNY175DG $1.6 TNY375 $1.3 F16-100HIP $1.6 MSD5043-I01 $12.00 MSD5043-100 5 $14.00 NCS2553 $5.50 ENC28J60ss $6.00 LAN9220-ABZJ $9.00 STE100P $8.00 LAN8710A-EZK $8.50 SGM8905 $6.80 MP2374DS $4.50 ali3606 ALCA $18.00 ali3501 B1 $7.00 C5707 100 $0.35 stv0299b 5 $6.00 EON Q64-104HIP $3.00 S29GL064N90TFI04 $5.50 S29GL256P90TFCR2 $12.5 H5PS1G63EFR-S6C $4.50 HY27UF084G2BTPCB $9 MC34063A $0.40 fd650s $3 ix2598 $3.2 sw2604 $1.20 RTL8201CP $1.60 FMS7000 $4.00 MP1482DS-LF $3.70 mp8126DF $5.00 TH20594MC1.4 5 $5.50 400v 22UF 13*20mm $0.45 панельки DIP8 -SOP8=200mil-10у.е dip40-TSOP56 M16=програматор тритон 50у.е +380673097415 |
| valik50 04/07/2013 07:07 |
новий приход
sti7105bud $37.00 STi7111-BUC $35.00 ap3502m-g1 $2.80 sw253G $1.40 TMO165R $1.40 SM8012 $1.40 G5628ADJT1U $2.80 m3606-alca $15 25V 1000UF 10*20mm $0.15 105 од100шт 16v 1000UF 8*16mm $0.13 105 од100шт 25v 470UF- 8*12mm $0.13 105 од100шт 16v 470UF 8*12mm $0.12 105 од100шт 35v 220UF 8*12 mm $0.12 105 од100шт |
| valik50 01/08/2013 16:13 |
новий приход
AR7241-AH1A AR8012-BG1A AR9287 - BL1A HER208 FR157 1n4007 LAN8710A-EZK ENC28J60ss LAN9220-ABZJ AOZ8212CI-05L ожидаються 2-7дней 5m0365r DH321 TM0265 TNY175DG dm0365r TNY375 SM8012 sw253G TMO165R |
| valik50 13/08/2013 07:59 |
новий приход
AR7241-AH1 10$ 50шт в наличии AR7240-AH1 8.5$ AR8012-BGA1 4.5$ AR9287-BL1A 6.5$ AR8032-BL1A 5$ HBS0565 1.5$ DM0265 TM0265 5m0365 ICE2B265 OB2263 sot23-6 cr6850t dip8 |
| valik50 29/08/2013 22:21 |
AR7241-AH1A
AR7240-AH1A AR8032-BL1A AR9280 - BL1A AR9283 - BL1A AR9287 - BL1A AR8012-BG1A F16-100HIP SG6848TZ1 M3329C G1 M3329D A1 STI5518BQC FQPF6N60C SM8012 dh321 ICE2B265 DM0265 TM0265 5m0365r 5L0380r dh321 HBS0565 SM8012 sw2604 but12 6n60 MP1484EN mp2374ds 74HC164 smd 74HC164 dip AS15-f RTL8201CP LAN8710A-EZK LAN9220-ABZJ ENC28J60/SS BS2S7VZ7306A Sharp F7VZ0194A S7VZ0502A s7vz0302a |
| valik50 22/09/2013 09:44 |
ПРОДАМ Xeltek USB SuperPro 500P Universal Programer --- 300 у.е
1.SuperPro 500P Programmer with a DIP48 Adapter 2.AC adapter 3.Software CD 4.USB Cable 5.User’s Manual 6.Optional Accessories: 7.Adapter in various packages 8.USB 2.0 Interfaced, ultra-high speed economy universal device programmer +++++++ в комплекте 7 переходников под разные типы микросхем 1pcs SOP8 150mil adapter 2pcs SOP8 208mil adapter 3pcs SOP28 300mil adapter 4pcs PLCC44 adapter 5pcs PLCC32 adapter 6pcs PLCC20 adapter 7pcs TSOP32/40/48 3 in 1 adapter бесплатная доставка по Украине 0673097415 |
| valik50 30/03/2015 21:24 |
новые цены
sti7105bud 22$ sti7101 bwd 22$ STI7110FTAUC 25$ STi7111-BUC 25$ STI5518BQC 7$ SPHE1512A 10$ SUNPLUS U2C+ ali3329d a1 5.5$ ali3329C F1 4.5$ ali3329 B1 6$ ali3606C ALCA 5$ ali3606 ALCA 5$ ali3501 B1 6$ MSD5043-I01 6$ FQPF6N60C 1$ BU808DFI 4.5$ S2000af plastic 1.5$ D1555 plastic 1.5$ sd4842p67k65 0.95$ від30шт 0.85$ sd4844p67k65 0.95$ від30шт 0.85$ 5L0380 to220p 1$ від30шт 0.95$ 5m0365 to220p 0.95$ від30шт 0.85$ 5m0365 0.75$ від30шт 0.65$ DM0365 0.75$ від30шт 0.65$ DM0265 0.75$ від30шт 0.65$ TM0265 0.75$ від30шт 0.65$ DH321 0.65$ від30шт 0.55$ SW8603 0.75$ від30шт 0.65$ sw2604 0.75$ від30шт 0.65$ CR6850T 0.75$ від30шт 0.65$ RM6222D 0.75$ від30шт 0.65$ 5L0365R 0.85$ від30шт 0.75$ TNY175DG 0.75$ від30шт 0.65$ TNY176PN 0.85$ від30шт 0.75$ ICE2B265 0.85$ від30шт 0.75$ ICE2B265 0.85$ від30шт 0.75$ SM8012 0.85$ від30шт 0.75$ VIPER22 0.85$ від30шт 0.75$ PC817 0.20$ TL431 0.19$ SGM8905 1.8$ NCS2553 1.5$ STE100P 8$ RTL8201CP 1.6$ ENC28J60ss 4$ LAN9220-ABZJ 8$ LAN8710A-EZK 4.5$ LAN8720A-EZK 4.5$ DRV632PWR 2.5$ WM8521 2.7$ PCM1725 1.5$ MP2374DS 3.5$ F9222L ZIP-13 4$ tda8174aw ZIP-11 2.5$ AT88SC0104CA-SU 2$ оригинал AT88SC0104CA-SU 1$ не оригинал cm1671b 5.5$ tps65161 4.5$ AP3041M-G1 4$ F9222L 4.5$ AS15-f 3$ TL1838B 1$ A6019A 5$ MZ73-18RM 1$ MZ72AL-9RM 1$ AIC1526-1 2.5$ AP3502 2.5$ FMS6145 2$ stv0299b 4$ MP1482DS-LF 2$ MP1484EN 3$ mp8126DF 3$ sy8009babc sot23-6 2.5$ u2c+ ca2ub-CA0TB-CA0VC SOT23-6 5$ F16-100HIP $1.6 EON Q64-104HIP $3.00 TC58NVG1S3ETA00 SOLO2 прошита 10$ S29GL064N90TFI04 5.50$ S29GL256P90TFCR2 10.5$ H5PS1G63EFR-S6C 4.5$ NT5CB128M16HP-DI 5$ u2c+ HY27UF084G2BTPCB 9$ 2SA928 TO-92L 0.35$ ST232BDR SOP16 0.55$ ST92195C3B1/OEO $8 8827CPNG4RV8 dip64 10$ TCL-A30V02-TO 8821CRNG5JB2 10$ JF0501-192381 8$ AR7241-AH1A оригинал 10$ AR7241-AH1A не оригинал 5$ с гарантией AR7240-AH1A оригинал 8$ AR8032-BL1A оригинал 3.5$ AR8035-BL1A оригинал 3.5$ AR9283-AL1A оригинал 3.5$ AR9280-AL1A оригинал 5.5$ AR9287-BL1A оригинал 3.5$ AR9342- BL1A оригинал 10$ AR9344-BC2A оригинал 10$ MX25L6406EM2I-12G SOP8 1.5$ MX25L6406EZNI-12GF WSON8 2.5$ ar2315a-001 оригинал 6$ SE2593A20 оригинал 4$ од 30шт по 3$ W9725G6JB-25 оригинал 5$ W9751G6KB-25 оригинал 5$ QA1 передачики на Nanobridge m5 3$ HN16614CG SOP16 2$ lsp5502 soic8 оригинал 1.5$ AOZ1212AL soic8 1.2$ SE5004L 3.5$ SE5003L 3.5$ sza5044z 5.5$ Ralink RT3050F 3.5$ ksz8721b tssop- 48 2.8$ KSZ8721BL QFN32 2.5$ BS2S7VZ7306A Sharp 9$ F7VZ0194A 8$ S7VZ0502A 5$ s7vz0302a 6$ 400v 22UF 13*20mm $0.35 105 від100шт 400v 47UF 13*25mm $0.50 105 від100шт 25V 1000UF 10*20mm $0.12 105 від100шт 16v 1000UF 8*16mm $0.11 105 від100шт 25v 470UF- 8*12mm $0.10 105 від100шт 16v 470UF 8*12mm $0.10 105 від100шт 35v 220UF 8*12mm $0.10 105 від100шт ПАНЕЛЬКА SA663 45$ ПАНЕЛЬКА SA683 45$ программатор халтек 500р 180$ б.у БП Orton 4100C 4.2$ БП OPENBOX X-800 5$ Материнка Orton 4100C 10$ Материнка GI8120 45$ +380673097415 |
| valik50 08/03/2016 22:02 |
новые цены
BCM7356ZZKFEB3G 44$ sti7105bud 22$ sti7101 bwd 22$ STI7110FTAUC 25$ STi7111-BUC 25$ STI5518BQC 7$ SPHE1512A 10$ SUNPLUS U2C+ SPHE6613A 7$ SUNPLUS U2C+ aliM3821-ALAAA 7.5$ ali3329d a1 5.5$ ali3329C F1 4.5$ ali3329 B1 6$ ali3606C ALCA 5$ ali3606 ALCA 5$ ali3501 B1 6$ MSD5043-I01 6$ msb1230-lf 3.6$ MST718BE-Lf 5.5$ FQPF6N60C 0.40$ не оригинал FQPF6N60C 1$ оригинал BU808DFI 4.5$ S2000af plastic 1.5$ D1555 plastic 1.5$ sd4842p67k65 0.95$ від30шт 0.72$ sd4844p67k65 0.95$ від30шт 0.72$ 5L0380 to220p 1$ від30шт 0.95$ 5m0365 to220p 0.95$ від30шт 0.95$ 5m0365 0.72$ від30шт 0.62$ DM0365 0.72$ від30шт 0.62$ DM0265 0.72$ від30шт 0.62$ TM0265 0.72$ від30шт 0.62$ DH321 0.62$ від30шт 0.52$ SW8603 0.72$ від30шт 0.62$ sw2604 0.72$ від30шт 0.62$ CR6850T 0.72$ від30шт 0.62$ CR6228T 0.72$ від30шт 0.62$ RM6222D 0.72$ від30шт 0.62$ 5L0365R 0.82$ від30шт 0.72$ TNY175DG 0.72$ від30шт 0.62$ TNY176PN 0.72$ від30шт 0.62$ ICE2A265 0.85$ від30шт 0.75$ ICE2B265 0.85$ від30шт 0.75$ SM8012 0.72$ від30шт 0.72$ VIPER22 0.72$ від30шт 0.62$ AM22A 0.72$ від30шт 0.62$ PC817 0.18$ TL431 0.17$ top222yn 2.2$ SGM8905 1.5$ NCS2553 1.3$ STE100P 7$ RTL8201CP 1.6$ ENC28J60ss 4$ LAN9220-ABZJ 8$ LAN8710A-EZK 4.5$ LAN8720A-EZK 4.5$ DRV632PWR 2.3$ WM8521 2.7$ PCM1725 1.5$ MP2374DS 2.5$ F9222L ZIP-13 4$ la78041 1$ tda8356 2.3$ tda8174aw ZIP-11 2.5$ AT88SC0104CA-SU 2$ оригинал AT88SC0104CA-SU 1$ не оригинал up6308ad 2.5$ ME4436 1.1$ SPP9527 1.2$ cm1671b 5.5$ tps65161 4.5$ mp3389ef 3.5$ AP3041M-G1 4$ AS15-f 3$ TL1838B 1$ A6019A 5$ MZ73-18RM 1$ MZ72AL-9RM 1$ AIC1526-1 2.5$ AP3502 2.5$ FMS6145 2$ stv0299b 4$ MP1482DS-LF 2$ MP1484EN 3$ mp8126DF 3$ sy8009babc sot23-6 2.5$ u2c+ ca2ub-CA0TB-CA0VC SOT23-6 5$ F16-100HIP $1.6 EON Q64-104HIP $3.00 TC58NVG1S3ETA00 SOLO2 прошита 10$ S29GL064N90TFI04 5.50$ S29GL256P90TFCR2 10.5$ H5PS1G63EFR-S6C 4.5$ NT5CB128M16HP-DI 5$ u2c+ HY27UF084G2BTPCB 9$ 2SA928 TO-92L 0.35$ ST232BDR SOP16 0.55$ ST92195C3B1/OEO $8 8827CPNG4RV8 dip64 10$ JF0501-192381 8$ AR7241-AH1A оригинал 10$ AR7241-AH1A не оригинал 5$ с гарантией AR7240-AH1A оригинал 8$ AR8032-BL1A оригинал 3.5$ AR8033-AL1A оригинал 6.5$ AR8035-BL1A оригинал 3.5$ AR8327-BL1A оригинал 5.5$ AR9283-AL1A оригинал 3.5$ AR9285-AL1A оригинал 4.5$ AR9280-AL1A оригинал 5.5$ AR9287-BL1A оригинал 3.5$ AR9331-AL3A оригинал 7$ AR9342- BL1A оригинал 7$ AR9344-BC2A оригинал 8$ ar2315a-001 оригинал 6$ MX25L6406EM2I-12G SOP8 1.5$ MX25L6406EZNI-12GF WSON8 2.5$ HN16614CG SOP16 2$ lsp5502 soic8 оригинал 1.5$ W9725G6JB-25 оригинал 5$ W9751G6KB-25 оригинал 5$ QA1 передачики на Nanobridge m5 3$ SE2593A20 оригинал 4$ од 30шт по 3$ AOZ1212AL soic8 1.2$ SE5004L 3.5$ SE5003L 3.5$ SZA5044z 5.5$ AWL5905 4.5$ LX5518 4.5$ Ralink RT3050F 3.5$ Ralink RT3052F 3.9$ ksz8721b tssop- 48 2.8$ KSZ8721BL QFN32 2.5$ BS2S7VZ7306A Sharp 9$ F7VZ0194A 8$ S7VZ0502A 5$ s7vz0302a 6$ 400v 22UF 13*20mm $0.35 105 від100шт 400v 47UF 13*25mm $0.45 105 від100шт 25V 1000UF 10*20mm $0.10 105 від100шт 16v 1000UF 8*16mm $0.09 105 від100шт 25v 470UF- 8*12mm $0.08 105 від100шт 16v 470UF 8*12mm $0.08 105 від100шт 35v 220UF 8*12mm $0.08 105 від100шт ПАНЕЛЬКА SA663 45$ ПАНЕЛЬКА SA683 45$ БП Orton 4100C 4.2$ БП OPENBOX X-800 5$ Материнка Orton 4100C 10$ Материнка GI8120 45$ Материнка для Т2 Trimax TR-2012 300грн |
| remid2007 13/03/2016 17:55 |
Материнка для Т2 Trimax TR-2012 300грн, актуально? Там скарт или тюльпан? |
| ярошенко 01/09/2016 19:13 |
А 6019А |
