Продаю MB,PSU,LED DRV для мониторов Iiyama РОССИЯ | |||
ДядяЮра 05/01/2015 15:26 |
Main board
4H.26N01.A11 2202570000P/T L24AIUL-BG67P 4H.26N01.A10 4H.26N01.A11 MA270-L01 2202555603P/T L27HPMB-AF67P 2202559701P/T 715G4640-M03-000-004L 4H.13901.A30 Power supply 4H.28102.A00 4H.28102.A00 2202149901P/T-01 LE18BW-2-1 LE18BW-2-1 2202149901P-01 HL270W-L01 2202150100P LE27BW-A-1 L0256-1M 48.7A912.01M 715G4497-P01-002-0V3S 715G4497-P02-002-0V3S L1242-1 48.7S201.011 LED Driver L22ADVH-AR57P 2202152100P/T-01 JL188DP52T 2202554900P/T L27HPMB-AF67P 2202151600P7T-01 4H.17633.A10 2202579201P/T 6207-L27AUDPCZ39P00 |
ДядяЮра 12/03/2015 21:28 |
Main board
4H.26N01.A10 4H.26N01.A11 5E26N0100 4H.26N01.A11 4H.0TB01.A10 5E.0T401.004 4H.13901.A30 L24AIUL-BG67P/2202570000P/T 6201-H24AKACBN67P00 L27HPMB-AF67P 2202559701P/T 6201-L22AIUBAF67P00 L9166-1 48.7D505.011 MA270-L01 2202555603P/T 6201-L22AIUHAA17P00 715G4640-M03-000-004L Power supply 4H.28102.A00 4H.28102.A00 4H.0UH02.A01 5E.0T402.002 TU08Q78 4H.0KH02.A00 TU08Q98 4H.0UH02.A00 T24B-U-1 2202141601P 6204-7924346K01 T24B-K-1 2202142001P 6204-7924336P01 L22ADVH-AR57P 2202152100P/T-01 L22CW-E-1 2202139401P JT229HP6EJ 6204-7922301E01 L22CW-E-1c 2202142300P JT220HP7KJ 6204-7922336H01 L24B-K-1 2202142801P JT240XX 6204-7924336K03 L27HPMB-AF67P 2202151600P7T-01 L0256-1M 48.7A912.01M 55.7Q902.001G L0256-1 48.7A912.011 55.7C703.002G L1242-1 48.7S201.011 55.7T703.001G L9344-1M 48.7C701.01M 55.7C703.001G L9344-2 48.7A909.021 55.7C7A3.M01G LE18BW-2-1 2202149901P/T-01 LE18BW-2-1 2202149901P-01 JL188PD12T 6204-7224006101 LE24AW-Y-1 2202148900P LJ240AIDRX 6204-L24AIUCAB67P00 LE27BW-A-1 2202150100P HL270W-L01 6204-L27AIMBAF67P00 JL188DP52T 2202554900P/T 715G2824-2 715G2824-4-5 715G2892-3 715G2892-3-8 715G3496-2 715G3727-P01-002-001M ADPCA1606QEJ 715G3727-P02-000-003M 715G4269-P03-001-001M 715G4497-P01-002-0V3S 715G4497-P1-002-0V3S ADPCA1603QEI 715G4497-P02-002-0V3S 715G4497-P02-002-0V3S ADPCD541GQEA 715G5079-P01-00M LED Driver 4H.17633.A10 4H.13933.A01 5E.0YP33.001 2202579201P/T 6207-L27AUDPCZ39P00 L22ADVH-AR57P 2202152100P/T-01 6207-H24AKACBN67P00 JL240XX 2202551601P 6207-L24AIUCAB67P03 715G3823-P01-000-004L LNPCAB362AQA8 HL270W-L01 2202556001P/T 6207-7227006001 |
ДядяЮра 18/03/2015 20:29 |
И не только Iiyama |
ДядяЮра 11/05/2015 13:04 |
Обновил. И не только Iiyama.
Main board 4H.26N01.A10 4H.26N01.A11 5E26N0100 4H.26N01.A11 4H.0TB01.A10 5E.0T401.004 4H.13901.A30 4H.0TB01.A10 RS5E.0T401.011 4H.0TB01.A10 RS5E.0T401.001 4H.0TB01.A10 5E.0NY01.014 L9166-1 48.7D505.011 L9166-1 48.7D505.011 65.7C7Z1.002 L24AIUL-BG67P/2202570000P/T 6201-H24AKACBN67P00 L27HPMB-AF67P 2202559701P/T 6201-L22AIUBAF67P00 L240AIUC-AB67PXXX 2202557800P/T 6201-L24AIUCAB67P03 MA270-L01 2202555603P/T 6201-L22AIUHAA17P00 MA270-L01 2202555603P/T 6201-L22AIUHAA67P00(17) 715G3603-M02-000-004L 756GQABCJY00000 715G2883-1-6 RS756GQ8CBY2002 715G2883-1-6 RS756GQ8CBY2004 715G2883-1-6 RS756GQ8CBY2001 715G3222-2 RS756GQ8CBJY002 715G3222-2 RS756GQ8CBJY003 715G3603-M02-000-004L 756GQABCJY00000 715G3603-M02-000-004L 756GQCCB0Y10320000 715G4640-M03-000-004L 715G4640-M03-000-004L 756GQCCB0Y10170000 715G4640-M03-000-004L 756GQBCBY100700 715G4640-M03-000-004L 756GQCCB0Y10060000 715G4640-M01-000-004K 756GQBCBY100200 715G4640-M01-000-004K 756GQBCBY101000 715G4640-M01-000-004K 756GQBCBY101200 6832203800P02 PTB-2038 55.7C701.001G MB-R2023L-DLE BLM1704M10119 JT198VP4YC5 2202531192P 6201-7998244Q21 JT240XX6KX 2202538501P REV2.01 RS6201-7924336K04 JT240XX6PX 2202542200P REV.1.00 RS6201-7924336P01 JT240XX6PX 2202542200P REV.1.00 RS6201-7924336D01 JT269HP6DJ 2202533302P VER 3.02 6201-7926336H02 VB-1501 4417108702F5 58190830300FH DA0WBCMB121 REV B RS21WBC0MB035 DA0UE1MB2A1 REV.A RS10MBZZZ045F Power supply 4H.28102.A00 5E.26N02003 4H.0UH02.A01 5E.0T402.002 4H.0KH02.A00 5E.0NY02.002 4H.0UH02.A00 5E.0T402001 4H.1UL02.A01 5E.1UL0201101100 4H.0BW02.A00 5E.DAB02001 4H.B0920.001/D2 27-D021625 T24B-U-1 2202141601P 6204-7924346K01 L22CW-E-1 2202139401P JT229HP6EJ 6204-7922301E01 L22CW-E-1C 2202142300P JT220HP7KJ 6204-7922336H01 L24B-K-1 2202142801P JT240XX 6204-7924336K03 L0256-1M 48.7A912.01M 55.7Q902.001G L0256-1 48.7A912.011 55.7C703.002G L1242-1 48.7S201.011 55.7T703.001G L9344-1M 48.7C701.01M 55.7C703.001G L9344-2 48.7A909.021 55.7C7A3.M01G LE18BW-2-1 2202149901P/T-01 JL188PD12T 6204-H24AKACBN67P00 LE18BW-2-1 2202149901P-01 JL188PD12T 6204-7224006101 LE24AW-Y-1 2202148900P LJ240AIDRX 6204-L24AIUCAB67P00 LE27BW-A-1 2202150100P HL270W-L01 6204-L27AIMBAF67P00 JT166W18-1 2202130400 6204-7966908171 JT198AP46-1 2202130000P 6204-7998907101 FM-60L12-AAB 27-D020336 EADP-35CF BA 715T2476-1 Ver B 715G2594-3 PWPC8942HQCY 715G2824-2 RSPWPC8C41MQWD 715G2824-4-5 RSPWPC8E41MQCV 715G2892-3 RSPWPC8C41MQCZ 715G2892-3-4 PWPC8A41EQWN 715G2892-3-8 715G3496-2 RSPWPC8921LQWM 715G3727-P02-000-003M RSPWPC9H41AQA3 AIP-0712H AIP-0180 REV10 AS02B018H01/1HYEZZZ097G TAI4024 PWB-1272-02 W2 TAI4024-CA1 715G3727-P01-002-001M ADPCA1606QEJ 715G4497-P01-002-0V3S ADPCA1603QEI 715G4497-P02-002-0V3S ADPCD541GQEA 715G5079-P01-000-003M ILPI-003 REV C 790401400600 ILPI-020 REV.B 490681400100R ILPI-023 REV A 490731400100R ILPI-024 REV A 490741400100R PI-LT03 REV 2.0 BLM100P60720 PI-SB03 REV D BLM1700P60210-2 DAC-12M033 REV.03A 27-D004260 DAC-19M005 27-D012873 https://yadi.sk/d/golsELBmhBDSY LED Driver 4H.17633.A10 4H.13933.A01 5E.0YP33.001 2202579201P/T 6207-L27AUDPCZ39P00 L22ADVH-AR57P 2202152100P/T-01 6207-H24AKACBN67P00 JL240XX 2202551601P 6207-L24AIUCAB67P03 715G3823-P01-000-004L LNPCAB362AQA8 HL270W-L01 2202556001P/T 6207-7227006001 |
ДядяЮра 10/06/2015 05:21 |
Main board https://yadi.sk/d/fQMZ3cJ6hLcod
A170E2-E03-H-0-6 35-D010627 A190A8-H-S5 35-D019445 A190E4-E04-H-S6 35-D013381 BTC-202A E220370 VX2439WM DA0WBCMB121 REV B 21WBC0MB035 DA0UE1MB2A1 REV.A 10MBZZZ045F DALAVPMB020 B3E 21LAVPMB054 DA0L9IMB2B1 BTI DS-1 B3E 29L91MB00E5 VB-1501 4417108702F5 58190830300FH SH-A94V-0 E154554(S) 22002518300 6201-7596908271 M220Z1-L09 S6/MV-094V-0/E88441 35-D036102 MA270-L01 2202555603P/T 6201-L22AIUHAA17P00 MA270-L01 2202555600P/T 6201-L22AIUHAA17P00 MB-R2023L-DLE BLM1704M10119/XLM19LA040002 MB-R2523B-DLA1 BLM19VAM10116/XLM19VA040005 L9141-1 48.7C703.011 PTB-2038 55.7C701.001G L9141-1M 48.7A605.01M PTB-2038 55.7C701.001G L9166-1 48.7D505.011 67.7Q9Z1.001 L9166-1 48.7D505.011 65.7C7Z1.002 L21A 2970036703 L24AIUL-BG67P 2202570000P/T 6201-H24AKACBN67P00 L27HPMB-AF67P 2202559701P/T 6201-L22AIUBAF67P00 L240AIUC-AB67PXXX 2202557800P/T 6201-L24AIUCAB67P03 JT198VP4YC5 2202531192P 6201-7998244Q21 JT229HP6EJ(2W) 2202535200P VER 1.00 6201-7922321G01 JT240XX6KX 2202538501P REV2.01 6201-7924336K04 JT240XX6PX 2202542200P REV.1.00 6201-7924336P01 JT240XX6PX 2202542200P REV.1.00 6201-7924336D01 JL240AI6EX 2202553001P/3000P 6201-7224316E01 JT269HP6DJ 2202533302P VER 3.02 6201-7926336H02 ILIF-105 792161300A00R ILIF-045 79102130011R ILIF-020 7907413000600R ILIF-187 790Y61300500R 4H.26N01.A10 5E.28101001 4H.26N01.A11 5E26N01003 4H.26N01.A11 5E.28101001 4H.13901.A30 5E.0YP01005 4H.0TB01.A10 5E.0T401.011 4H.0TB01.A10 5E.0T401.001 4H.0TB01.A10 5E.0NY01.014 4H.0TB01.A10 5E.0T401.004 4H.0BW01.A00 5E.0AB01.001 4H.1UL01.00 CMI 5E.1UL01.015 39-Y2830100G010 70-Y2832500G000 0171-2271-4684/CK66 3 94V-0/E85792 3523-0432-0150 2202522100P 6201-7998907101 715G1558-1-VS 984KH5VWP 715G2805-1 756GQ9CBVV05800 715G2883-1-6 756GQ8CBY1001 715G2883-1-6 756GQ8CBY2001 715G2883-1-6 756GQ8CBY2002 715G2883-1-6 756GQ8CBY2003 715G2883-1-6 756GQ8CBY2004 715G3222-2 756GQ8CBJY002 715G3222-1 756GQ8CBJY003 715G3222-2 756GQ8CBJY003 715G3225-1-2 756GQ8C8VV064 715G3502-1 VER D 756GQACBY100100 715G3603-M02-000-004L 756GQABCJY00000 715G4640-M01-000-004K 756GQBCBY100700 715G4640-M01-000-004K 756GQBCBY101000 715G4640-M01-000-004K 756GQBCBY101200 715G4640-M02-000-004K 756GQCCB0Y10060000 715G4640-M03-000-004L 756GQCCB0Y10320000 715G4640-M03-000-004L 756GQCCB0Y10110000 715G4640-M03-000-004L 756GQCCB0Y10170000 Power supply https://yadi.sk/d/sQLmNABqhLcrk 4H.28102.A00 5E.26N02003 4H.0UH02.A01 5E.0T402.002 4H.0KH02.A00 5E.0NY02.002 4H.0UH02.A00 5E.0T402001 4H.1UL02.A01 5E.1UL0201101100 4H.0BW02.A00 5E.DAB02001 4H.B0920.001/D2 27-D021625 T24B-U-1 2202141601P 6204-7924346K01 L22CW-E-1 2202139401P JT229HP6EJ 6204-7922301E01 L22CW-E-1C 2202142300P JT220HP7KJ 6204-7922336H01 L24B-K-1 2202142801P JT240XX 6204-7924336K03 L0256-1M 48.7A912.01M 55.7Q902.001G L0256-1 48.7A912.011 55.7C703.002G L1242-1 48.7S201.011 55.7T703.001G L9344-1M 48.7C701.01M 55.7C703.001G L9344-2 48.7A909.021 55.7C7A3.M01G LE18BW-2-1 2202149901P/T-01 JL188PD12T 6204-H24AKACBN67P00 LE18BW-2-1 2202149901P-01 JL188PD12T 6204-7224006101 LE24AW-Y-1 2202148900P LJ240AIDRX 6204-L24AIUCAB67P00 LE27BW-A-1 2202150100P HL270W-L01 6204-L27AIMBAF67P00 JT166W18-1 2202130400 6204-7966908171 JT198AP46-1 2202130000P 6204-7998907101 FM-60L12-AAB 27-D020336 EADP-35CF BA 715T2476-1 Ver B 715G2594-3 PWPC8942HQCY 715G2824-2 PWPC8C41MQWD 715G2824-4-5 PWPC8E41MQCV 715G2892-3 PWPC8C41MQCZ 715G2892-3-4 PWPC8A41EQWN 715G2892-3-8 715G3496-2 PWPC8921LQWM 715G3727-P02-000-003M PWPC9H41AQA3 AIP-0712H AIP-0180 REV10 AS02B018H01/1HYEZZZ097G TAI4024 PWB-1272-02 W2 TAI4024-CA1 715G3727-P01-002-001M ADPCA1606QEJ 715G4497-P01-002-0V3S ADPCA1603QEI 715G4497-P02-002-0V3S ADPCD541GQEA 715G5079-P01-000-003M ILPI-003 REV C 790401400600 ILPI-020 REV.B 490681400100R ILPI-023 REV A 490731400100R ILPI-024 REV A 490741400100R PI-LT03 REV 2.0 BLM100P60720 PI-SB03 REV D BLM1700P60210-2 DAC-12M033 REV.03A 27-D004260 DAC-19M005 27-D012873 FM-136A16 27-D023780 PLHL-T826A 2722 171 00751 LSEP1287BE LSJB1287-21 TNP4G469AA TNPA4221AE TXN/P1HNTB LED DRIVERS https://yadi.sk/d/PkJeeGechLcnL 4H.17633.A10 5E19V33001 4H.13933.A01 5E.0YP33.001 L22ADVH-AR57P 2202152100P/T-01 6207-H24AKACBN67P00 JL240XX 2202551601P 6207-L24AIUCAB67P03 715G3823-P01-000-004L LNPCAB362AQA8 HL270W-L01 2202556001P/T 6207-7227006001 L27HPMB AF67P 2202151600P/T 6207-L27AIMBAF67P00 JL88DP52T 2202554900P/T 6207-L22AIUHAA17P00 |
ДядяЮра 19/06/2015 09:05 |
Обновил |
ДядяЮра 07/07/2015 09:25 |
Продаю ЗИП Viewsonic, Iiyama,Benq,Philips,Aser,AOC РОССИЯ |
clericmonitor 21/07/2015 09:25 |
Подскажите стоимость платы 4H.13933.A01, и как доставка осуществляется? |
ДядяЮра 21/07/2015 09:44 |
clericmonitor, Мыло напиши. |
ДядяЮра 21/07/2015 13:51 |
clericmonitor, Ты же в личку ответить не можешь.Мыло напиши. |
ДядяЮра 22/06/2016 13:30 |
Продаю. http://spare-parts.club/index.htm |
ДядяЮра 11/07/2016 14:19 |
ДядяЮра 17/08/2016 15:45 |
ДядяЮра 04/09/2016 07:43 |
ДядяЮра 31/10/2016 20:24 |
ДядяЮра 16/11/2016 09:04 |
ДядяЮра 04/12/2016 16:55 |
ROOTkit1 20/01/2017 14:27 |
ДядяЮра, привет. Есть в наличии Блок питания для монитора ViewSonic VLED221WM (VS12053)
FM-60L12-AAB и сколько будет стоить? Доставка в регионы? Заранее спасибо! |
ДядяЮра 04/03/2017 01:06 |
ДядяЮра 23/03/2017 05:37 |
oskin 05/04/2017 20:29 |
Нужен LED driver 4h.17633.a10
ДОБАВЛЕНО 05/04/2017 20:30 ДядяЮра, 4h.17633.a10 Есть? |
ДядяЮра 08/04/2017 14:37 |
oskin, А в списке или на сайте он есть? http://spare-parts.club/index.htm |
ДядяЮра 27/04/2017 19:31 |
ДядяЮра 25/05/2017 22:19 |
ДядяЮра 11/08/2017 13:49 |
ДядяЮра 26/09/2017 06:13 |
ДядяЮра 11/10/2017 10:13 |
ДядяЮра 01/11/2017 07:50 |
ДядяЮра 29/01/2018 05:17 |
ДядяЮра 21/02/2018 18:47 |
ДядяЮра 17/03/2018 18:54 |
ДядяЮра 06/04/2018 20:00 |
ДядяЮра 16/04/2018 17:47 |
ДядяЮра 03/07/2018 07:44 |
ДядяЮра 23/07/2018 08:21 |
ДядяЮра 29/08/2018 11:55 |
ДядяЮра 14/09/2018 06:22 |
ДядяЮра 01/10/2018 18:14 |
ДядяЮра 16/10/2018 14:02 |
ДядяЮра 27/10/2018 17:29 |
ДядяЮра 10/11/2018 14:36 |
ДядяЮра 22/11/2018 19:02 |
ДядяЮра 19/12/2018 09:45 |
ДядяЮра 07/01/2019 16:39 |
ДядяЮра 09/02/2019 20:09 |
ДядяЮра 25/02/2019 20:21 |
ДядяЮра 29/03/2019 18:50 |
ДядяЮра 09/04/2019 20:34 |
ДядяЮра 15/05/2019 19:58 |
ДядяЮра 03/06/2019 18:29 |
ДядяЮра 23/06/2019 13:06 |
ДядяЮра 08/07/2019 19:37 |
ДядяЮра 23/07/2019 20:46 |
ДядяЮра 14/09/2019 18:19 |
ДядяЮра 12/10/2019 15:05 |
ДядяЮра 14/11/2019 17:59 |
ДядяЮра 13/12/2019 13:13 |
ДядяЮра 05/01/2020 15:24 |
ДядяЮра 13/02/2020 14:53 |
ДядяЮра 23/02/2020 16:59 |
