Платы для LCD и PDP телевизоров | |
| Parus033 27/01/2017 19:43 |
MainBoard:
MainBoard AMT26041 (тюнер F21WT-3BAR-E) от mistery MTV-2622LW MainBoard BN41-01632C MainBoard BN41-01785A MainBoard LG LD21B/LC21B EAX64317403(1.0) G4_L_TU1 23 MainBoard LG LC/LD/LE42B, 42G EAX65384005(1.2) MainBoard TOSHIBA PE1 063 (V28A001396A1) Power PSU: Power PSU P3237F1 ASM PSLF211401A REV 1.3 Power PSU KB-5150 (от TV MISTERY MTV-2622LW) Power PSU TV SHARP DUNTKE100WE QPWBSE100WJZZ Power PSU TV SHARP PSD-0553 RDENCA267WJQZ Power PSU plcd190P3 24432 Power PSU APS-317 (SONY) Power PSU 3104 313 61643 (3104 303 50523) Power PSU SONY 1-878-661-12 (GT3 PS6203 PS6204) Power PSU BN44-00191A Power PSU BN44-00510B Power PSU BN44-00492A PD32AV0 CSM PSLF450A04A REV1.1 Power PSU BN44-00492A PD32AV0 CSM PSLF450A04A REV1.2 Power PSU BN44-00330B Rev: 1.1 Power PSU BN44-00510B Rev: 1.2 Power PSU BN44-00442B Rev: 1.2 Power PSU BN44-00610B (L46SF_DPN) Power PSU LG EAX63329901/10 (EAY62171101) Power PSU LG EAX64427001(1.4) EAY62608801 (PSLF-L116A) Power PSU LG EAX62865601/8 Power PSU LG EAX65424001(2.7) micom Ver 1.10b Power PSU TOSHIBA N11-150P1A (V71A00022901) Инверторы: Inverter SSI320 4UH01 Rev0.3 Inverter SSI320_8C01 REV:2.0 Inverter SSI320_4US01 REV:0.0 Inverter SHARP RUNTKA497WJQZ Inverter SHARP RDENC2540TPZ F IM3857 U84PA-E0006102D Inverter CEM-1-97 CMO 1260B1-12D Inverter CEM-1-97 CMO I315B1-16A Inverter SHARP RDENC2299TPZZ (60) QKITF0169SNP2 Inverter CIU11-T0040 Inverter 6632L-0421A LGIT PNEL-T605 Rev-04 (2300KFS021B-F) inverter PHILIPS VIT71020.66 LG LED driver PCLC-D002 J REV0.0 6917L-0045C TOSHIBA LED driver SSL460_3E1B Rev:0.1 T-con: T-con F60MB4C2LV0.6 T-con 6870C-0243C (LC420/LC470WUN-SBA1 T-con 6870C-0151A (LC320WX5-SLB1) T-con VD T260XW02 V7 / T315XW02 VD 06A63-11 T-con T315HW07 VB CTRL BD T-con V26C3C1.0 T-con V260B1-C04 T-con Sharp CPWBX3775TP T-con 320AB03C2LV0.3 T-con BN41-01938B (13Y FHD_60Hz V02) LG Logic DFD-2 GA-HF-14 E213009 LG Logic EAX63986201 (EBR72680701) T-con 12PSQBC4LV0.0 Планки подсветки: BN96-21475A (32H-3535LED-32EA) – 2 шт. 3660L-0373A 201 (FA 07 19 A) – 2 шт. TOSHIBA 46-LEFT LJ64-03495A LG 74.42T23.001-2-DS1 (12326N) Кнопки, джойстики, ИК – приемники: Кнопка включения SAMSUNG PDP (9/Q9/C9) Блок кнопок - FD910WJ - KD910 Блок кнопок 3139 123 6185.1 Wk548.4 Блок кнопок 3139 123 5974.1 V3 Блок кнопок 3139 123 6219.1 v4 WK642.3 Блок кнопок с IR-приемником D550 12C BN41-01600C (BN96-16729D) Джойстик E450/E490 BN41-01804A Rev: R1.3 Джойстик с IR-приемником UE4000 BN41-01858C - 2 шт. Джойстик с IR-приемником UF5000/1.2T BN41-01976B (BN96-26411C) Джойстик с IR-приемником E450/E490 BN41-01804A Rev:1.3 - 2 шт. Сенсорные кнопки с IR-приемником LC430/530/550 BN41-01382A (BN96-13022B) Сенсорные кнопки с IR-приемником LW4500/LV2500/LK550_V1.7 IR SENSOR 715G3406-2 IR SENSOR 3330119540021 (E16641) IR SENSOR QPWBXE457WJN4 (DUNTKE457WE) IR SENSOR SHARP KD909 (ND909WJ) IR SENSOR LG EBR72650101 IR SENSOR 3139 123 6210.1 WK632.5 IR SENSOR 3139 123 6171.1 Wk537.5 IR SENSOR 3139 123 5972.2 IR SENSOR с кнопками 3104 313 61692 1507 IR SENSOR SO2012 MT5367 IR S1303-1 IR SENSOR SONY A1663488C 1-878-663-13 (1-730-490-13) IR SENSOR E22E9100_IR.PCB R28-S00178-0220 IR SENSOR LG YWB8291301A 0X1FC7 IR SENSOR LG YWB3R9VB.0A EBR74561003 LM35-55 VER 2.2 IR SENSOR с индикацией TOHIBA PE1 069 (V28A00140101) IR Assy YN167F1 (EBR78480601) WiFi/BT Combo module LGSBW41 (2703H- LGSBW41) WIBT20 BN96-17107A Разное: Плпта usb acer 5920 / 5920G daozd1TB6FO Плата tvmistery 303C2631062 (LJ41-10276A 51EF XB_UP LJ92-01893A REV NO:R1.7 (LJ92-08193A) 139 123 5956.2 Wk613.5 Плата тюнера DUNTKD984WE QPWBND984WJZZ (RTUNQA035WJZZ) Плата CI QPWBXD628WJN3 KD628 NOISE FILTER IG-N06BES NOISE FILTER ID-N10AEN - 2 шт. BN41-01823 BN41-00863A - 2 шт. QPWBFD604WJN4 KD628 QPWBXD628WJN3 3139 123 6229.1 v2 WK633.2 LK-LE240408A DUNTKE491WE (QPWBFE491WJZZ) 303C2631062 TV2631-ZC02-01(B) DUNTKD984WE (QPWBND984WJZZ) тюнер RTUNQA035WJZZ (TDQG2-002A) 3139 123 5970.2 WK510.2 - 2 шт. Плата с тюльпанами KE099WE QPWBFE099WJZZ PDP: Z SUS LG EAX63529101 ZSUB LG EAX63551401 REV:D X-main Board LJ41-06005A (LJ92-01482B) X-main Board 420H LJ41-09478A X-main Board 420DH YM LJ41-09479A X-main 50U(F)2P (LJ41-08475A) Rev:1.3 X-main 42”HD W3 (1layer) LJ41-06004A R:1.0 Y-main 50U(F)2P (LJ41-08458A) Rev:1.3 XY-main 51EHF_XYM LJ92-01861A (LJ41-10170A) Rev:1.5 Y board 42HD W3 YB LJ41-05077B REV: R1.0 50 EF YB (2layer) LJ41-10172A R 1.3 (LJ92-01871A) 50 U2P YB (2layer) LJ41-08459A R 1.3 42DH YB LJ41-09480A R1.6 (LJ92-01798A) Samsung logic main 42”HD W3 LM (LJ41-05078A) Rev: R1.72 (LJ92-01485) Samsung logic main 42HD/500H LJ41-09475A Rev: R1.6 Samsung logic main 51EF_NON_3D_LM LJ41-10278A Rev: R1.1 Samsung logic main 50U2P LM LJ41-08387A Rev: R1.1 (LG92-01705) X Buffer 42" HD W3 XB(1 LAYER) LJ41-06003A REV:R1.0 F- Buffer 42”HD WD LB LJ41-05080A Rev: R1.31 (LJ92-01487A) E- Buffer 42”HD WD LB LJ41-05079A Rev: R1.31 (LJ92-01486A) Buffer Board XL 50T3_XL EAX63332802 REV:B Buffer Board XC 50T3_XC EAX63332902 REV:B Buffer Board XR 50T3_XR EAX63333002 REV:B Buffer Board 51EF_XB_LOW LJ41-10171A Rev: R1.5 (LJ92-01870A) Buffer Board 51EF XB_LOW LJ41-10171A Rev: R1.7 (LJ41 Много шлейфов |
| se2000 04/03/2019 17:32 |
Здраствуйте ! интересует БП BN44-00610B |
| Anonymous 24/04/2021 10:46 |
Цена? |
