Switching between devices on XM3?
MaxiBelas
Сообщение #1 От 18/09/2021 01:05 цитата
I was just about to buy the XM3s, but then watched a random Youtubers long term review. He said that you cannot switch between multiple devices, but will have to disconnect and re-pair the headphones every time? Is it true? Don't the XM3 support pairing with 8 devices and then when you want to switch, you can just tap connect on the other device?192.168.0.1 router login 192.168.1.1
1
777
