| sasha19722201 24/02/2019 09:28 |
| Ingh писал: | sasha19722201, схему скачай на это шасси, там на 11 странице есть метод входа в сервисный режим. Там и поправишь панель.
ДОБАВЛЕНО 24/02/2019 09:24
To enter into Factory Menu in case of “Factory Key” is disabled, please to follow below steps: - press Remote Control key “MENU” to display main menu - press the subsequence Remote Control keys “7”, “9”, “1” and “5” - press Remote Control key “MENU” to exit main menu - press Remote Control key “MENU” to display main menu again The main menu will display ”FACTCORY” at the last item To pop-up Factory Menu in case of “Factory Key” is enabled, please to follow below step: - press Remote Control key “Blue” To enable/disable “Factory Key”, please to follow below steps: - press Remote Control “OK” key to enter into “System” submenu - press Remote Control “RIGHT ”or “LEFT” key till “Factory Key” item - press Remote Control “OK” key to toggle mode To exit “Factory Menu”, press “Exit” key from Remote Control. To comeback to “Factory Menu” root when you are into a submenu: - press Remote Control “RED” key.
Большое спасибо за помощь ---попробую отпишусь
2.2. Entering to “P” Mode
To enter into “P” mode, an external serial 3.3VDC device is required for sending relevant commands. See appendixp “Serial Command Protocol for MTKxx”.
ДОБАВЛЕНО 24/02/2019 09:26
sasha19722201, ты сам хоть что то пробовал искать или сразу за помощью? http://archive.espec.ws/redirect.php?dlid=27698 |
