My aspire 315 shutdown on its own | |
| m1anjul 29/06/2025 14:50 |
My laptop sometimes shutsdown on its own while it's plugged in and won't turn on/completely unresponsive when opening via power button. Only opens back up after I manually press the battery reset button on its underside. I've only had this laptop for a year and honestly don't know the cause why this started happening 10.0.0.0.1 192.168.1.254 . |
| zokalmo1 09/10/2025 17:49 |
А можно как-нибудь проверить блок питания, который идёт в комплекте? Может, купить универсальный и проверить? Если ничего не поможет, просто верните универсальный. |
