DVD плеер Sony DVP-S7000 - 5 зона нужна | |||
| Basiloff 03/03/2005 19:52 |
помогите советом / прошивкой .
Заранее благодарен. |
| scooters 04/03/2005 18:50 |
Есть вот что но сам не пробывал |
| Мираж 04/03/2005 20:35 |
scooters, файл повреждён |
| Rottor 04/03/2005 21:26 |
Все открывается, и выглядит так:
----------------------------------------------------------------------------------------------------------------------------------------------------- The Ultimate DVD Upgrade S7000 Sony DVP-S3000 & DVP-S7000 DVD MOD Kit Manual Macrovision disable All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems. User manual Put your player into „Standby“ Mode and enter one of the following commands if necessary: Remote control command Function [0] [ENTER] default Players default region [1] [ENTER] Region 1 [2] [ENTER] Region 2 [3] [ENTER] Region 3 [4] [ENTER] Region 4 [5] [ENTER] Region 5 [6] [ENTER] Region 6 [0] [AUDIO CHANGE] Automatic region switching OFF [0] [ANGLE CHANGE] default Automatic region switching ON [1] [AUDIO CHANGE] Video interference impulses ON (Macrovision ON) [1] [ANGLE CHANGE] default Video interference impulses OFF (Macrovision OFF) [2] [AUDIO CHANGE] User operation prohibitions* and Access Restrictions ON [2] [ANGLE CHANGE] default User operation prohibitions* and Access restrictions OFF [3] [AUDIO CHANGE] Sync on Green [3] [ANGLE CHANGE] default Sync on Video [4] [AUDIO CHANGE] IRE 7.5 [4] [ANGLE CHANGE] IRE 0.0 [4] [SUBTITLE CHANGE] default IRE default [5] [AUDIO CHANGE] RGB [5] [ANGLE CHANGE] YUV [5] [SUBTITLE CHANGE] default RGB/YUV default The selected region code is unfortunately not visible in the Service Menu. * The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angleswitch. „Play Limited/Play Impossible“ If this error message should appear: - enter the setup of your player - go to parental control - enter the password 1234 - set parental control level to something else - leave the setup - power off - power on - enter the setup of your player - go to parental control - enter the password 1234 - set parental control level to off - power off - power on Your player does no longer display the message above now! |
| Profyguy 05/03/2005 02:46 |
Сомневаюсь, что это поможет, т.к. это
Иными словами, это инструкция по пользованию МОДЕРНИЗИРОВАННЫМ с помощью MOD Kit аппаратом. MOD Kit обычно включает в себя микруху с указаниями, как ее подключить. А вот где это Kit купить, похоже, никто толком не знает. ![]() |
| BBKuser 06/03/2005 23:32 |
И будет Вам-счастье http://www.brouhaha.com/~eric/video/dvd/sony_dvp_s7000/#switches ![]() |
| A-SERVICE 17/04/2005 14:46 |
Инфо- искать по Инету- бесполезно.Эти аппараты делаются, но с применением аппаратных средств.
То есть с применением спец-оборудования. Аппарат должен попасть в руки мастеру по апгрейду, тот в свою очередь сначала сохраняет заводское не тронутое ПО из микросхем плеера, потом подвергает его воздействию спец-оборудования, если сразу не получится, то опытным путем находит верное решение. В конце концов, если "фокус" не удался, аппарат просто возвращается в исходное состояние (r1) и возвращается обратно клиенту на руки. Но, в данном случае это мало вероятно - аппарат не самый сложный. Главное, что бы он попал на руки тому кто этим занимается давно. |
