DVD SONY DVP-NS725P мультизона | |
| arpel 15/12/2005 13:36 |
КТО нибидь подскажите как включить мультизону в DVD SONY DVP-NS725P Привезена кажется со Штатов Вообщем стоит Вторая зона |
| valera_k 15/12/2005 22:05 |
DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region: Turn On the unit with the remote controller Wait until "no disc" appears in the unit's display Press Pause, 3, 1, 4, 1, 5, 9 The word "CODE" should appear in the display Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on Again, within 5 seconds, press Pause and Power If the above fails to work then you may wish to try the following: Put the player into Standby mode Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off Press Audio and Return for auto-switching On Press Angle and Return for MacroVision On Press Subtitle and Return for MacroVision Off Успехов ! ![]() |
| deny 16/12/2005 17:29 |
Все это херня,переделывается физически,резюками... |
