I NEED DIAGRAM SCHEMATIC SCANNER KODAK I2600 | |
| eletmoraes 13/11/2016 21:49 |
It stops working when I turn on the power supply A / C .
When I turn on the power supply A / C the code 0 appears on the display. Is it possible to find the schematic diagram of the device or manual service ? |
| n max 13/11/2016 22:03 |
https://www.kodakalaris.com/b2b/solutions/document-scanners/desktop/i2820-scanner/support/~/media/Files/DI/uploadedFiles/Document_Imaging/Products/Document_Scanners/Workgroup/i2400/i2000-UG_A61677_en.pdf
Тут страница 31 написано что это такое,даже по англицки. Походу вы интерфейс прибили-это мысли вслух |
