Kyocera KM-1500 ошибка C-7 980 | |
| John-80 21/01/2008 16:07 |
что за ошибка, откуда взялась и как её устранить? |
| tokar 22/01/2008 09:33 |
John-80, мануал есть здесь:
ftp://ftp.runnet.ru/Hardware_Documentation/copiers/Kyocera_MITA/KM1500/KM1500_SM_UK_Rev1.pdf C7980 Waste toner reservoir overflow probrem (when the total number of copies is less than 100 thousand sheets). After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5g. Defective waste toner sensor. Defective engine board (KP-5061). Replace the waste toner sensor and check for correct operation. Replace the engine board (KP-5061) and check for correct operation. |
