CHINA | |
| Barracuda 01/09/2009 14:11 |
29T1A-S 76832 HYF-31J
followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29T1A-S (G) 76828B followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T2A-P 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MENU" button in maintenance cycle of the menu options 29T2A -P (A) 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29T2A-P (G) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T5A-S (G) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T6A-P 8844 HYF-29A in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in maintenance cycle of the menu options . 29T6A-P (A) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T7A-T (A) 76828 +1232 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T7A-T (B), 29T8D-T 29T8D-T (A) 76828B +1532 HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T8D-T 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29T8D-S 29T8D-S (A), 29T8D-T (G) 76828 HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29T9A-P, 29T9B-P 8843 HYF-31D in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MENU" button in the Maintenance menu, select circle. 29TE 9373 HTR-018 followed by user remote control of mute, OSD ,-/--, display, mute key combination to enter the maintenance menu D29FV6-A8 MST5C16 HYF-33M straight press "display, image mode, Sound mode, Calendar "button to enter the bus to adjust. Press the mute button to adjust the next page, press the menu key to exit the bus to adjust status. 29F18 8843 35A in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu, select circle. HS-2995 8844 HYF-34A in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in maintenance cycle of the menu options . HS-2996 HS-2996 (A) 76832 followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. HP-2999 HP-2999 (G) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. HP-2999 (NC) 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. HP-2999A 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu, select circle. 29F1A-P 29F1A-P 8844 HYF-29A in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu loop select. 29F5A-T (AB) where (B) for the 8829A (No Subwoofer) HYF-35H hand by holding down the volume on the TV button until the screen display to a volume of 00, do not let go, press the remote control's " DISP "button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, child lock menu, type "9,4,4,3" can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) 29F5A-T (C) 76828B +1532 HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode . Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5A-T (E) 76828 (non-bass feature) +1532 +1265 HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" Key, that is, into the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5A-T (D) 76828 +1232 with a heavy bass HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5A-T (G) 8829B hand by holding down the volume on the TV button until the screen display to a volume of 00, do not let go, press the remote control of the "DISP" button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, child lock menu, type "9,4,4,3" can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) 29F5D-T 76828 +1232 (with side AV and heavy bass) HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, that is, access to factory maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5D-T (B) 76828 (no side AV and heavy bass) HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5D-TA 1225 movement movement HYF-35L 1225 bus automatically replace the new version LA76930 entered the bus, the method as follows: first volume reduced to "0", and then on the remote control "menu key" "5" seconds or more , the screen appears "password ----" words, and then enter" 9,4,4,3 "access" FACTORY "state. Repeat the above steps to turn into the "ADJ B / W" and "OTPION" state; replacement LA76930 new version, the first bus will be required to enter "OPTION5" the last one set to "O". D29FV6-A8 MST5C16 HYF-33M straight press "display, image mode, Sound mode, calendars and" key to enter the bus to adjust. Press the mute button to adjust the next page, press the menu key to exit the bus to adjust status. 29F5D-TA 1225 movement movement HYF-35L 1225 bus automatically replace the new version LA76930 entered the bus, the method as follows: first volume reduced to "0", and then on the remote control "menu key" "5" seconds or more , the screen appears "password ----" words, and then enter" 9,4,4,3 "may Into the "FACTORY" state. Repeat the above steps to turn into the "ADJ B / W" and "OTPION" state; replacement LA76930 new version, the first bus will be required to enter "OPTION5" the last one set to "O". 29F9K-PY by remote control menu button 40B after enter "1269" into the bus, according to the sound adjustment mode, press "Menu" button and press "turn back at the" exit. 29F88 TA1276AN press the MENU button on the remote control once, the screen displays a mute symbol; 2, once again press the MENU key while you press the TV MENU button will enter maintenance mode, upper right corner of the screen are "S "display. 29F5D-T (S) 76828 +1232 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F5D-TA MK14 HTR-038 keyboard while pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V - adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F5D-TA (B) PW1225 HYF-35L with the 40A (new) remote click "static" key into the bus in the limited time to watch the password type "9,4,4,3" (original 35L with remote control) you can unlock. Note: The 40A remote control type "0,5,5,4" can also be unlocked. 29F5D-TA (G) 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V + . V-adjusted data M37281MFH-085SP, M37281MAH-058SP Haier 29F6G-PN MK14 HYF-31L at the same time by pressing the keyboard of this machine P-. and the V-key for 3 seconds. into the bus state, use the menu button on the menu next page, P +. P-to select the adjustment items, with the V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F6G-AN 3D +6656 HYF-31P press the remote control on the "TIMER" button, then press the number key "1,2,2,9" into the bus, adjust the "Menu" button next page, in the boot state, according to child lock on the remote control button "LOCK" key can unlock. 29F6G-PNT 3D +6656 HYF-31P press the remote control on the "TIMER" button, then press the number key "1,2,2,9" into the bus, adjust the "Menu" button next page, in the boot state, according to child lock on the remote control button "LOCK" key can unlock. 29F6G-PNT (A) PW1235 HYF-40B press the "Menu" button, then press the number key "1,2,6,9" into the bus in the boot state, according to child-lock on the remote control button "LOCK" button Xie lock. 29F6G-PNT (B) PW1235 HYF-40B press the "Menu" button, then press the number key "1,2,6,9" into the bus in the boot state, according to child-lock on the remote control button "LOCK" button Xie lock. 29F6G-PNT (G) 3D +6656 HYF-31P press the remote control on the "TIMER" button, then press the number key "1,2,2,9" into the bus, adjust the "Menu" button next page, in the boot mode, press the remote control The child lock button "LOCK" key can unlock. 29FA6-PN 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29FV6-PH2 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. D29FV6H-C 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. N29FV6H-D LA76930 + PW1225 +1265 HYF-35L with the 40A (new) remote click "static" key into the bus in the limited time to watch the password, type "9,4, 4,3" (first wife 35L remote control) can be solution lock. Note: The 40A remote control type "0,5,5,4" can also be unlocked. D29FV6H-F Mitsubishi + PW1235 +1265 HYF-40B press the "Menu" button, then press the number key "1,2,6,9" into the bus in the boot state, according to child-lock on the remote control button "LOCK" key can unlock. 29F1A-P (B) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F2A-S (A) 76828 followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F3A-N 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V - adjustment data. 29F5A-T 8809A HTR-023 hand by holding down the volume on the TV button until the screen display to a volume of 00, do not let go, press the remote control of the "DISP" button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, The child lock menu, type "9,4,4,3," you can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) 29FV6H-B 8829A HYF-35H hand by holding down the volume on the TV button until the screen display to a volume of 00, do not let go, press the remote control of the "DISP" button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, child lock menu, type "9,4,4,3" can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) 29F7A-T 8809A HTR-023 hand by holding down the volume on the TV button until the screen display to a volume of 00, do not let go, press the remote control of the "DISP" button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, child lock menu, type "9,4,4,3" can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) 29F7A-T (AB) 8829A (No Subwoofer) +9656 HYF-35H hand by holding down the volume on the TV button until the screen display to a volume of 00, do not Let go, press the remote control of the "DISP" button. Upper right corner of the screen will show "S" characters, and then press the volume keys to zero by holding down the OSD button, you can enter the D mode, child lock menu, type "9,4,4,3" can unlock. See the specific operating instructions. (Note: 37T88 machine is the universal password) are the same 29F7A-T (C) 76828 HYF-33E f ollowed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F7A-PN MK14 (progressive) HYF-31L at the same time by pressing the keyboard of this machine P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V + . V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F7A-PN (G) 833 + HD + VGA HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments , with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F7A-PN (G) 833 + HD + VGA HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments , with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F7A-PN (C) 833 + SAA4955 + P15V330) HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-to select the adjustment project, with the V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F8D-T 29F8D-T (P) 9373 --- V1.0 +1265 HTR-018 followed by user remote control of mute, OSD ,-/--, display, mute key combinations to enter service menu. 29F8D-T (A) 76828 +1232 with a heavy bass HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F8D-T (B) 76828B +1265 +1532 no bass HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F8D-T (C) 76828 HYF-33E followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F8D-PY MK14 HYF-31K at the same time by pressing the keyboard of this machine P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V - adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F8D-PY (N) MK14 (progressive) HYF-31L at the same time by pressing the keyboard of this machine P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments , with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F8D-PY (G) 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F95 8844 HYF-34A in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu, select circle. 29F95 (G) 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29F96 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu, select circle. 29F96 (NC) 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29F96 (G) 76828 followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F98 29F98 (G) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F99 29F99 (A) 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29F99 (H) 76828 HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. 29F9A-PF 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in maintenance cycle of the menu options . 29F9A-P 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in maintenance cycle of the menu options . 29F9A-S 76832 HYF-31J followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. In the boot mode, press the remote control on the child lock button "LOCK" key can unlock. 29F9B-PF 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in the Maintenance menu, select circle. 29F9D-P 8843 HYF-31H in the normal startup, press on the remote control "PSTD", "SSTD", "CALL", "POWER" key combinations to enter the maintenance menu, click "MEUN" button in maintenance cycle of the menu options . 29F9D-P (G) 9373 HTR-018 followed by user remote control of mute, OSD ,-/--, display, mute key combination to enter the maintenance menu 29F9B-PY MK14 HYF-31K at the same time by pressing the keyboard of this machine P-. and the V-key for 3 seconds. into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "child lock "function select" off "can be unlocked. 29F9B-PY (N) MK14 (progressive) HYF-31L at the same time by pressing the keyboard of this machine P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments , with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F9G-PN 833 (no VGA, and HD) HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-to select the adjustment items, with the V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F9G-PN (G) 833 (HD + VGA) HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-to select the adjustment project, with the V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F9G-PN 833 HYF-40A at the same time the keyboard by pressing the native P-. And the V-key for 3 seconds. Into the bus state, use the menu button on the menu next page, P +. P-selection adjustments, with V +. V-adjusted data will be set up sub-menu system functions in the "Child Lock" function select "off" can be unlocked. 29F9G-S, 29F9G-S (A) 76828 +1265 +1232 S HYF-33D followed by pressing the menu, "MENU" button, display button, mute button, and the "SCAN" button, or enter the plant maintenance mode. Press sleep timer button, change the main menu. The child lock menu, type "8,2,8,0," you can unlock. See the specific operating instructions. CH-13G 1, with K6I / F remote control, press the "M" key, then press and hold "Display" + "image" button 3 to 5 seconds, enter the bus data, use the "show +", "program -," "Volume + "," Volume - "to flip, adjust the data. 2, the main chip CH04T1306 (LA769317N57R4-E), CH04T1303 (LA769337N57N7-E) of the machines available K18G, K13A remote access. Specific methods are as follows: 1), the volume set to 0, the image is set to "bright", press "order" button, enter the 'M'; 2), press "Menu" button, the image displayed on the menu, press the "Sort "key to enter the bus data 3), with a left arrow, down arrow keys to flip, adjust the data. 3 out of bus data: 1) by "M" button; 2), remote shutdown. |
