JVC AV-28SD4EN | |
| Vitaly 10/07/2004 16:17 |
:help: нужен сервисный режим, ТВ из Англии, нужно включить метры. Тюнер заменил. |
| Sem 10/07/2004 19:50 |
А ты перепробовал варианты из сервисного меню, что на "Телемастере"? |
| ROMAS2 11/07/2004 01:27 |
Vitaly, maybe JVC AV-28S4EK ( chassis MX-IV ; processor M37204MC-A45SP ) ? |
| Vitaly 11/07/2004 10:59 |
ROMAS2, скорее всего,такой, аппарат на работе. |
| ROMAS2 11/07/2004 12:29 |
For service mode press at the same time on original R.C (RM-C663 ) . buttons " DISPLAY" and
" VSM standart " ( replacement remote does not allow pressing two buttons together ) . If you have not remote RM-C663 - use any JVC ORIGINAL remote control ( with the same command system ) . Service mode code is the same . Keys combination for service mode depends on remote ( not on tv model ). For example i use RM-C695 ( service mode : DISPLAY + VSM STD ) enter into all JVC service mode. Some other R.C. : RM-C770 - DISPLAY + CINEMA/GAME ; RM-C795 - " i " + " mute " RM-C873 - DISPLAY + VSM etc. For VHF service mode will not help you.. Add fifth diode ( counting from tv front side ) into diodes line beside processor ( processor's options diodes). Sorry i didn't find diode number in my notes. Complete service manual : http://wimtv.be/techniforum/viewtopic.php?p=8118 Service mode describtion. Language-Polish. |
| Vitaly 12/07/2004 00:00 |
Thank you very much for valuable information. ![]() |
