SHARP 66GF-63H Tелик из Англии ? | |||||
| danail 17/09/2004 12:08 |
У телик нет DK и BG . Tюнер полной . Какое шаси??.Проц. ST10R272LT1 |
| AII Ex 17/09/2004 13:32 |
DA-50W Шасси
SERVICE MODE The service mode is provided to enable the engineer to correctly set up the receiver to the CRT fitted in the set. Note that these adjustments may vary from one receiver to another. To enter the service mode, carry out the following procedure. 1. Connect a test pattern to the antenna terminal. 2. Tune the receiver to this signal. 3. Turn the receiver off using the mains switch. 4. Press volume down and channel up buttons on the front of the receiver at the same time. 5. Keeping these buttons pressed, turn the mains on. 6. When the set starts up it will be in service mode. 7. Release the two buttons. Use the channel up and down buttons to move between the options. Use the volume control buttons to change the data. To store the data, use the stand-by button on the remote control. To exit the service mode, turn the receiver off using the mains switch. When the service mode is entered the following On Screen Display appears -SERVICE SOFTWARE AND HEXADECIMAL COUNTER DISPLAY: SW ON XXXX SW OFF XXXX HOURS ON XXXX The figures displayed in the XXXX locations are hexadecimal representations of the number of times that particular function has been executed. For example if the hexadecimal number displayed after SW ON was 0E4A, this would correspond to the receiver being turned on 3658 times. Добавлено 17-09-2004 14:32 DA-50W Шасси SERVICE MODE The service mode is provided to enable the engineer to correctly set up the receiver to the CRT fitted in the set. Note that these adjustments may vary from one receiver to another. To enter the service mode, carry out the following procedure. 1. Connect a test pattern to the antenna terminal. 2. Tune the receiver to this signal. 3. Turn the receiver off using the mains switch. 4. Press volume down and channel up buttons on the front of the receiver at the same time. 5. Keeping these buttons pressed, turn the mains on. 6. When the set starts up it will be in service mode. 7. Release the two buttons. Use the channel up and down buttons to move between the options. Use the volume control buttons to change the data. To store the data, use the stand-by button on the remote control. To exit the service mode, turn the receiver off using the mains switch. When the service mode is entered the following On Screen Display appears -SERVICE SOFTWARE AND HEXADECIMAL COUNTER DISPLAY: SW ON XXXX SW OFF XXXX HOURS ON XXXX The figures displayed in the XXXX locations are hexadecimal representations of the number of times that particular function has been executed. For example if the hexadecimal number displayed after SW ON was 0E4A, this would correspond to the receiver being turned on 3658 times. |
| danail 17/09/2004 13:58 |
Какие опции нада изменит в сервис за BG / DK |
| danail 18/09/2004 16:31 |
помогите!!! |
| AlexM 18/09/2004 21:12 |
Никакие , ставьте конвертер или ищите прошивку ROM от 70GF63Е. Может получится, у меня нет этой прошивки. Нашёл какую-то если есть желание попробуйте, но необходимо предварительно сохранить прошивку NVM и проинициализировать сновой ROM. |
| Вано 18/09/2004 21:39 |
AlexM Я не понял примочку нада а не конвертор.......... звук то 6.0................................................ |
| andyli 18/09/2004 21:52 |
попробуй заменить в конверторе выходной фильтр 5.5 на 6.0 -ставь и подстрой выходной контур в конверторе. |
| AlexM 18/09/2004 22:37 |
Я тоже не понял . Что есть
Я ставил конвертер 6.0 в 6.5 гетеродин 500 кГц. на пьезо фильтре. |
