thomson 21dmb06kh Цвет в меню.
edik ka
23/06/2020 12:11
шасси etc009
Память - 24C16W
SMPS - TDA16846-2P + 2SK2936
Тюнер - TEDE9-284B
Звук - TDA7266SA
FBT - BSC25-0252T
HOT - 2SC5885
Красный надо убавить а зелёный добавить.Не смог найти где настраивать.
Пробовал везде - + но цвет не меняется.В каком каталоге настройка ?
Boris Gorbunkov
23/06/2020 15:00
3.6. WHITE BALANCE
White Balance adjustment (neutral)
a) Input RF Black and White pattern signal (PAL).
b) Press "1" key to enter white balance adjustment (Page 1:Fig.6)
c) Measure the dark side of the picture with a color analyzer.
Adjust RED and GRN until the data on the analyzer
become x=284 +/-8, y=299 +/-8.
d) Measure the bright side of the picture.
Adjust WPR, WPG and WPB until the data on the analyzer
e) Repeat step c and d until you get right white balance
on both dark and bright side of the screen.
f) Input RGB Black and White pattern signal (PAL).
g) Measure the dark side of the picture with a color analyzer.
Adjust REDC and GRNC until the data on the
analyzer become x=284 +/-8, y=299 +/-8.
h) Measure the bright side of the picture.
Adjust WPRC and WPGC and WPBC until the data on the
i) Input SECAM L Black and White pattern signal.
j) Measure the dark side of picture with a color analyzer,
Adjust REDSECAM and GRNSECAM until the data on
the analyzer become x=284 +/-8, y=299 +/-8.
ДОБАВЛЕНО 23/06/2020 16:03
СМ прилагаю.
edik ka
23/06/2020 15:57
Плату кинескопа отремонтировал и всё получилось.
