Panasoniс шасси EURO 9 вход в сервис?
RSIV
28/10/2004 14:02
Как войти в сервисное меню телевизора Panasoniс с шасси EURO 9???
Вано
28/10/2004 22:11
Интересно а ты о нем больше ничего не знаеш???????? может еще расказал на чем он собран..............................................
alaus!
29/10/2004 08:19
1. Set the Bass to maximum position, set the Treble to minimum position, set the Volume to minimum then press the
down button (-/v) on the customer controls at the front of the TV and at the same time press the INDEX button on the
remote control, this will place the TV into the Service Mode 1.
2. Press the RED / GREEN buttons to step up / down through the functions.
3. Press the YELLOW / BLUE buttons to alter the function values.
4. Press the STR button after each adjustment has been made to store the required values.
5. To exit the Service Mode, press the "N" button.
