Universum FT4286 вход в сервис | |
| Шрек 28/03/2006 15:49 |
Процессор : SDA5255-A052 ; видео – TDA8844 , шасси : E9/a.
Как войти в сервисное меню телевизора ? Вариант “ TV – I – STOP “ не открывает , а необходимо подправить геометрию. Заранее благодарю. |
| VRV 28/03/2006 16:19 |
Шрек попробуй ещё раз |
| Konstantin 28/03/2006 20:12 |
Шрек, название темы изменено, будь внимателен !!! |
| Шрек 30/03/2006 23:34 |
открывает !!!!!!!!!!! |
| VRV 31/03/2006 12:19 |
Шрек пульт родной ? |
| Шрек 31/03/2006 13:44 |
Пульт родной, все функции выполняет. |
| VRV 31/03/2006 15:30 |
Странно ![]() |
| reset 31/03/2006 17:58 |
Chassis E9-service manual
SERVICE ADJUSTMENTS OF THE COLOUR TV WITH E9 CHASSIS All necessary adjustments and settings are performed during manufacture of TV set and assure its correct operation when connected to the mains voltage and antenna or external video or audio signal. When TV set requires service intervention all settings should be checked and corrected, if necessary. DEMAGNETISING OF PICTURE TUBE Correctness of picture tube demagnetising is usually automatically checked. Magnetisation of picture tube is presented as one or more colour "clouds", consequently colour reproduction of the picture is not correct. Each time the TV set is switched on with mains switch, demagnetising system is activated. For correct demagnetising procedure disconnect the TV set with mains switch and leave it disconnected for about 15 minutes. Afterwards when you switch on the TV, demagnetising procedure is performed. In case distortion of colour reproduction still persists, special demagnetising coil should be used. ADJUSTMENT ADJUSTMENT CONDITION ADJUSTMENT ACTIVITY AND RESULT OF SETTINGS 1. SUPPLY VOLTAGE FOR HORIZONTAL OUTPT STAGE »B+« • Connect the TV set to supply voltage 175…250VAC. • Switch it on and set it by means of remote controller to AV mode of operation. • Connect DC voltmeter to D-602 cathode. With P-601 potentiometer set supply voltage for horizontal output stage to: • 90° CTV: 118V ±0,2V • 110° CTV: 155V ±0,2V • 110°/16:9 CTV: 155V ±0,2V SWITCHING TO SERVICE MODE All other service settings of TV set are made in so called service mode of TV set operation. To enter this mode of operation press the keys in the following sequence: "TV", "I", and "STOP" in the period of 5 seconds from switching on the TV set to normal mode of operation. When the TV set is switched over to service mode the following status line with service parameter and parameter value appears on the screen: |
