imran khan
Repair TV PHILIPS 32PFL3605/60
chassis TPM4.1E LA
Composition chassis TPM4.1E LA: Panel: LC320WUY-(SC) (B1)
MAIN: 715G3786-M1A-000-004X
PSU & INVERTOR: 715G3816-P01-
H20-002U
MT8222TMMU
W9425G6EH-4 TL2428MCP02
25Q32BVSIG
TPS65192
ATMLHOO8 32C
TPA3110D2
Tuner: TAFT-S712D UBA2071A
TNY277PN G6961SZ
Problem
TV does not turn on, the LED on the
front panel flashes on and off when
you connect the network. After
several attempts to start may start a
few tens of seconds, and then turn off.
At the time of operation is controlled with the remote and keyboard. Off is
preceded by any artifact on the image
or sound: Disintegration pictures,
bands or strong sound background
cure.
Measure the voltage at the output of
the power supply and DC / DC
converters found no crime. All
voltages are consistent with the
pattern of error devices. Please note
that the problem began to disappear with increasing number of attempts to
turn, which clearly points to the
capacitive nature of the defect. Used
for localization of hot air station,
slightly raise the temperature of a thesmall area of scheme, followed by the inclusion of the control and heated
the next section. As a result of these
experiments was found faulty
component. They found a filter capacitor power
converter for voltage S7147 1B digital supply of the processor MT8222.
Ripple on the capacity of 0.2 - 0.3
volts, the output voltage to 1V is
critical. His replacement restore your TV (S7147 was invalid TKE and the
nominal capacity). In the process of repairing the TV Pilips PHILIPS 32PFL3605/60 used: Service manual and schematic
chassis TPM4.1E LA
Pleasae Add a comment
RAMMER
Что было первым курица или яйцо ?
That was the first the chicken or the egg ? |
imran khan
both comes togather,
And eat thd mango and do not count trees. |
Telik
Перевел на всякий случай переводчиком в интернете:
Проблема:
ТВ не включается. Светодиод на передней панели вспыхивает и выключается, когда Вы соединяете сеть. После
несколько попыток начаться может включиться на несколько секунд, и затем выключается.
Во время операции управляется с отдаленным и клавиатурой. Прочь предшествовавший любым экспонатом на изображении или звук: Картины Распада, группы или сильный звуковой фон
лечение.
Измерьте напряжение в продукции
электропитание и DC / DC
конвертеры не нашли преступления. Все
напряжения совместимы с
образец ошибочных устройств. Пожалуйста, отметьте
то, что проблема начала исчезать с растущим числом попыток к
поворот, который ясно указывает на
емкостная природа дефекта.Б/У
для локализации станции горячего воздуха,
немного поднимите температуру thesmall области схемы, сопровождаемой включением контроля и нагретой
следующая секция. В результате их
эксперименты были сочтены дефектными
компонент. Они нашли власть конденсатора фильтра
конвертер для напряжения S7147 1B цифровая поставка процессора MT8222.
Рябь на способности 0.2 - 0.3
В, выходное напряжение к 1 В
важный. Его замена восстанавливает Ваше ТВ (S7147 был недействительным TKE и
номинальная способность). В процессе восстановления ТВ Pilips PHILIPS 32PFL3605/60 использовал: Инструкция по эксплуатации и схематичный
шасси TPM4.1E LA
Как я понял, человек поделился, как отремонтировать данный аппарат при таком дефекте... |
vebs
Белгородец
imran khan
With due respect all,
I am here just learn from your side of world ,And i let your kind notice that i can not advertise any link of my website in this forum as you can mention. |
vebs
Белгородец
| Мля !Тебе же написали. УВАЖАЙ ФОРУМЧАН! ПИШИ НА РУССКОМ! Твои проблемы с переводом мало кого волнуют. |
CHETLAN
| Telik писал: | | Как я понял, человек поделился, как отремонтировать данный аппарат при таком дефекте... | и на кой все это нужно (тем более на английском), если каждый будет писать про замененные литы, то весь форум засрать можно. Выносят мОск такие деятели, нашел по цепям питания дохлый лит и рассказывает всем, прям бином ньютона  |
RAMMER
imran khan
Уважаемые участники форума, я
хочу узнать от вас людей, а также
поделиться тем, что я есть  |
semvictor
| Telik Зачем выложил тупой гугловский перевод?Думаешь кому поможет замена стаба,кот. imran khan описывает..Это для 2 класса.Тс писиет от восторга,что победил бяку,а остальным это зачем? |
vebs
Белгородец
Так он потрох все переводит в англиский и засирает тут мозги своим языком. А вообще он торгаш. Продает мануалы за деньги.
| imran khan писал: | Уважаемые участники форума, я
Оказывается умеешь пользоваться переводчиком! Вот и пиши на русском. |
semvictor
Nik_Al
Старый таёжник
| CHETLAN писал: | | Telik писал: | | Как я понял, человек поделился, как отремонтировать данный аппарат при таком дефекте... | и на кой все это нужно (тем более на английском), если каждый будет писать про замененные литы, то весь форум засрать можно. Выносят мОск такие деятели, нашел по цепям питания дохлый лит и рассказывает всем, прям бином ньютона  |
+1
Всё это давно уже проглочено и высрано... не только мной. Все более-менее опытные мастера знают о ТКЕ, и о том, что литы имеют свойство менять параметры при нагреве. Я давно такие литы феном выявляю.
ДОБАВЛЕНО 15/01/2013 21:41
| semvictor писал: | | vebs, А он хитрый! |
Видимо за лохов тут нас держит
Интересно, знает ли он значение этого слова?  |
semvictor
Вообще-то imran khan делится своим опытом(последние его темы об этом).Переводите,хотя-бы,Гуглом и читайте с поправкой на такой перевод!Посмотрите последние его темы на форуме(их несколько).
ДОБАВЛЕНО 15/01/2013 23:51
vebs А перевел он тоже Гуглом  |
