samsung 510NW Burnt green 2A fuse, not power | |
| eletmoraes 28/11/2013 18:35 |
replaces 2A fuse, but when connecting the monitor, the Q203 transistor SMD inverter output exploded. board source code is IP24135A. I searched the internet and found a site that transistor Q203 should be KTC1624 will be? Does this transistor switching only the monitor back up and running? |
| TE 28/11/2013 23:04 |
Transistor must be KTD1624. Verify or replace the resonant capacitor. Verify MOSFET. |
| Сергей92 29/11/2013 00:34 |
Exploded, he's probably not so simple... |
| snoopy 29/11/2013 01:50 |
Сергей92, Just! Knowledge needed! ![]() |
