NL3224AC35 tft 5.5''
boddax
28/03/2015 08:04
hello all , i have trouble with this , gray view , missing 5V output from one of two T1451 porotection shutdown or damaged IC? looking for schematics . Thanks people.
Привет всем, у меня есть проблемы с этим, серую зрения, пропавших без вести выход 5V один из двух T1451 porotection выключения или повреждения IC? Ищу схемы. Благодарности люди.
5pin not 3
boddax
28/03/2015 23:26
component smd sot23-5 or sot-25 its 5 pins not 3 , 12vcc power supply pin9 of t1451a is ok the out1 is ok too but the out2 pin10 expected 5v because its the vcc for ta8996f min vcc must be 5v , the load beetween pin10 and gnd is 230ohm , any help apreciated thanks.
