Dell inspiron N5010 erratic shut down | |
| Mohamed Kamel 25/04/2014 02:07 |
Dell inspiron N5010 intel platform has erratic shut down issues, sometimes at P.O.ST screen, others long time after windows login.
Steps already taken : -Fan cleaned, new paste added for CPU and GPU -Ram and Hard drive tested ok- Did anyone experience this situation with N5010 or have any clue as where to dig further ? A prompt reply should be largely appreciated. Thank you |
| JohnK 25/04/2014 05:12 |
Write a post code in which the stop. |
| Mohamed Kamel 27/04/2014 18:28 |
As mentioned, lap shuts down erratically : either at different stages of post screen or during (or after) logging to windows and that complicates the issue.
Heat is normal |
| JohnK 28/04/2014 22:26 |
than the temperature measured? |
| Sergej 29/04/2014 00:32 |
Mohamed Kamel, is ME-Region in BIOS clear (new)? Try to translate: http://vlab.su/viewtopic.php?f=181&t=6897
http://vlab.su/viewtopic.php?f=181&t=7012 |
