HP PAVILLON DV6 with display fail | |
| Mohamed Kamel 25/04/2014 02:27 |
Hi
Hp pavilion Dv6 has neither internal nor external display. Fan is running, hard drive spinning. Steps taken : Tried with only mobo and new ram to no avail. Is DV6 prone to graphic problem, same as DV 6000-9000...series? Any suggestion as where to dig further is welcome. Thank you Platform : DAOQT8MB6GO REV: G |
| JohnK 25/04/2014 05:18 |
The operating system boots? If so, change the GPU. |
| Mohamed Kamel 27/04/2014 18:42 |
Further steps taken : I reflowed GPU and NB and Display came. Will see if it's a momentary or a permanent fix. |
| JohnK 28/04/2014 22:24 |
it will not work for long. but you vysnilos cause. chip must be replaced. |
