Сбой в программе микроволновой печи Panasonic NN-CD997S
arhimondus
27/09/2012 05:54
Здравствуйте.
При старте высвечивается H97
lesnik178
27/09/2012 06:21
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board
http://www.eletrodomesticosforum.com/es/cursos/horno_microondas/Inverter.pdf
stoves
27/09/2012 08:57
Перед стартом читай Правила создания темы http://monitor.espec.ws/section37/topic198524.html
arhimondus писал:
http://monitor.espec.ws/section37/topic147665p40.html
http://monitor.espec.ws/section37/topic202801.html
http://monitor.espec.ws/section37/topic147658.html
